Netonix switch ( WS-8-150-DC ) has a problem to power up equipment using POE, when enabling the voltage weather 48volt or 24 it works only for few minutes then switches of equipment but when trying to use the with no POE its working properly.
How to solve this issues ? is it possible to solve remotely ?
Problem to power up
- muhammedmunas
Re: Problem to power up
Please provide some information.
Make sure your running v1.4.8
Describe how your powering the WS-8-150-DC
Describe your site.
Describe your site.
- muhammedmunas
The site is a tower where we are co-siting for our radio network.
The site has AC power and solar which charges a battery bank. This battery bank has an output of 48volts which we tapped through to a circuit breaker then to our Netonix switch.
muhammedmunas wrote:The site is a tower where we are co-siting for our radio network.
Questions:
1) Firmware version, if not v1.4.8 please upgrade
2) Is this a positive or negative DC site? (if this is negative 48V that is your problem)
You should bench test this unit as described in this post: viewtopic.php?f=6&t=2780#p19221
