New root on port -11
KBrownConsulting
Has thanked: 15 times
Been thanked: 18 times
Sat Oct 21, 2017 8:22 am
I'm seeing a bunch of entries in the log referring to negative port numbers such as the one shown below:
Oct 21 01:22:35 STP: MSTI0: New root on port -11, root path cost is 220000
What exactly is "port -11" referring to? These logs are being generated on a WS-6-MINI running v1.4.8rc12 but it has been happening since at least v1.4.8rc7
Eric Stern
Been thanked: 130 times
Re: New root on port -11
Sat Oct 21, 2017 10:11 am
Seeing the entire log would be helpful.
KBrownConsulting
Sat Oct 21, 2017 9:16 pm
Sure, below is the full log from another switch. (I realize the log below is from a switch running 1.4.8rc7 but unfortunately I cleared the log on the switch running rc12 right after my previous post. The important point though is that rc12 is behaving exactly the same way.)
The reason for all the learning, forwarding, discarding messages on the 20th & 21st is because someone plugged in a cable they shouldn't have and caused a bridging loop. But you'll notice that there are those negative port references periodically on days prior as well. I'm curious if that's a bug or if it's communicating something I simply don't understand how to interpret.
Thanks.
Code: Select all
Dec 31 14:00:06 netonix: 1.4.8rc7 on WS-6-MINI
Dec 31 14:00:10 system: Setting MAC address from flash configuration: EC:13:B2:91:90:4E
Dec 31 14:00:11 system: starting ntpclient
Dec 31 14:00:12 admin: adding lan (eth0) to firewall zone lan
Dec 31 14:00:19 Port: link state changed to 'up' (1G) on port 1
Dec 31 14:00:19 STP: set port 1 to discarding
Dec 31 14:00:19 Port: link state changed to 'up' (1G) on port 5
Dec 31 14:00:19 STP: set port 5 to discarding
Dec 31 14:00:19 STP: MSTI0: New root on port 2, root path cost is 20000
Dec 31 14:00:19 STP: set port 1 to learning
Dec 31 14:00:19 STP: set port 1 to forwarding
Dec 31 14:00:19 STP: set port 5 to learning
Dec 31 14:00:19 STP: set port 5 to forwarding
Dec 31 14:00:21 dropbear[729]: Running in background
Dec 31 14:00:23 switch[755]: Detected cold boot
Dec 31 14:00:24 switch[755]: PoE enabled on port 6, PoE Smart is starting cable check
Dec 31 14:00:25 system: starting ntpclient
Dec 31 14:00:29 switch[755]: Port 6 cable check results: Ok, Ok, Ok, Abnormal termination
Dec 31 14:00:29 switch[755]: Port 6 passed PoE Smart cable check, turning on power
Dec 31 14:00:33 Port: link state changed to 'up' (100M-F) on port 6
Dec 31 14:00:33 STP: set port 6 to discarding
Dec 31 14:00:35 STP: set port 6 to learning
Dec 31 14:00:35 STP: set port 6 to forwarding
Dec 31 14:00:36 system: starting ntpclient
Dec 31 14:00:47 system: starting ntpclient
Dec 31 14:00:53 Port: link state changed to 'down' on port 6
Dec 31 14:00:53 STP: set port 6 to discarding
Dec 31 14:00:55 Port: link state changed to 'up' (100M-F) on port 6
Dec 31 14:00:55 STP: set port 6 to discarding
Dec 31 14:00:57 Port: link state changed to 'down' on port 6
Dec 31 14:00:58 system: starting ntpclient
Dec 31 14:00:59 Port: link state changed to 'up' (100M-F) on port 6
Dec 31 14:00:59 STP: set port 6 to discarding
Dec 31 14:01:01 STP: set port 6 to learning
Dec 31 14:01:01 STP: set port 6 to forwarding
Dec 31 14:01:09 system: starting ntpclient
Dec 31 14:01:20 system: starting ntpclient
Dec 31 14:01:32 system: starting ntpclient
Dec 31 14:01:36 STP: MSTI0: New root on port -11, root path cost is 220000
Dec 31 14:01:36 STP: set port 1 to discarding
Dec 31 14:01:36 STP: set port 1 to learning
Dec 31 14:01:36 STP: set port 1 to forwarding
Sep 26 17:24:10 system: time set by NTP server
Oct 2 12:35:51 STP: MSTI0: New root on port 2, root path cost is 20000
Oct 2 12:36:13 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 2 12:36:13 STP: set port 1 to discarding
Oct 2 12:36:13 STP: set port 1 to learning
Oct 2 12:36:14 STP: set port 1 to forwarding
Oct 11 15:20:18 STP: MSTI0: New root on port 2, root path cost is 20000
Oct 11 15:21:15 STP: set port 6 to discarding
Oct 11 15:21:15 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 11 15:21:15 STP: set port 6 to learning
Oct 11 15:21:15 STP: set port 6 to forwarding
Oct 11 15:21:15 STP: set port 1 to discarding
Oct 11 15:21:15 STP: set port 1 to learning
Oct 11 15:21:15 STP: set port 1 to forwarding
Oct 12 02:36:31 STP: MSTI0: New root on port 2, root path cost is 20000
Oct 12 02:37:27 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 12 12:05:13 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 16 03:34:02 STP: MSTI0: New root on port 2, root path cost is 20000
Oct 16 03:34:56 STP: set port 6 to discarding
Oct 16 03:34:56 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 16 03:34:56 STP: set port 6 to learning
Oct 16 03:34:56 STP: set port 6 to forwarding
Oct 16 03:34:56 STP: set port 1 to discarding
Oct 16 03:34:56 STP: set port 1 to learning
Oct 16 03:34:56 STP: set port 1 to forwarding
Oct 17 16:51:59 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 17 23:03:48 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 17 23:03:48 STP: set port 1 to discarding
Oct 17 23:03:48 STP: set port 1 to learning
Oct 17 23:03:48 STP: set port 1 to forwarding
Oct 19 15:08:46 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 20 14:17:13 STP: set port 1 to discarding
Oct 20 14:17:13 STP: set port 1 to learning
Oct 20 14:17:13 STP: set port 1 to forwarding
Oct 20 14:34:33 STP: set port 6 to discarding
Oct 20 14:34:33 STP: set port 6 to learning
Oct 20 14:34:33 STP: set port 6 to forwarding
Oct 20 14:34:36 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 20 14:34:36 STP: set port 1 to discarding
Oct 20 14:34:48 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 20 14:34:50 STP: set port 1 to learning
Oct 20 14:34:50 STP: set port 1 to forwarding
Oct 20 14:34:50 STP: MSTI0: New root on port 2, root path cost is 20000
Oct 20 14:34:50 STP: set port 6 to discarding
Oct 20 14:34:51 STP: set port 6 to learning
Oct 20 14:34:51 STP: set port 6 to forwarding
Oct 20 14:35:32 STP: set port 6 to discarding
Oct 20 14:35:32 STP: set port 6 to learning
Oct 20 14:35:32 STP: set port 6 to forwarding
Oct 20 14:36:31 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 20 14:36:31 STP: set port 1 to discarding
Oct 20 14:36:31 STP: set port 1 to learning
Oct 20 14:36:31 STP: set port 1 to forwarding
Oct 20 16:28:10 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 20 16:34:04 STP: set port 6 to discarding
Oct 20 16:34:04 STP: set port 6 to learning
Oct 20 16:34:04 STP: set port 6 to forwarding
Oct 20 16:34:21 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 20 18:10:34 Port: link state changed to 'down' on port 5
Oct 20 18:10:34 STP: set port 5 to discarding
Oct 20 18:10:53 Port: link state changed to 'up' (1G) on port 5
Oct 20 18:10:53 STP: set port 5 to discarding
Oct 20 18:10:55 STP: set port 5 to learning
Oct 20 18:10:55 STP: set port 5 to forwarding
Oct 20 18:10:59 Port: link state changed to 'down' on port 5
Oct 20 18:10:59 STP: set port 5 to discarding
Oct 20 18:11:01 Port: link state changed to 'up' (1G) on port 5
Oct 20 18:11:01 STP: set port 5 to discarding
Oct 20 18:11:03 STP: set port 5 to learning
Oct 20 18:11:03 STP: set port 5 to forwarding
Oct 20 21:30:17 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 20 21:30:17 STP: set port 1 to discarding
Oct 20 21:30:32 STP: set port 1 to learning
Oct 20 21:30:47 STP: set port 1 to forwarding
Oct 20 21:55:16 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 20 21:55:46 STP: set port 1 to discarding
Oct 20 21:55:46 STP: set port 1 to learning
Oct 20 21:55:46 STP: set port 1 to forwarding
Oct 20 21:55:47 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 20 21:59:00 STP: set port 6 to discarding
Oct 20 21:59:00 STP: set port 6 to learning
Oct 20 21:59:00 STP: set port 6 to forwarding
Oct 20 21:59:15 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 20 21:59:17 STP: MSTI0: New root on port 2, root path cost is 20000
Oct 20 21:59:17 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 20 22:34:45 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 20 22:34:45 STP: set port 1 to discarding
Oct 20 22:34:59 STP: set port 1 to learning
Oct 20 22:35:09 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 20 22:35:09 STP: set port 1 to discarding
Oct 20 22:35:10 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 20 22:35:23 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 20 22:35:23 STP: set port 1 to learning
Oct 20 22:35:23 STP: set port 1 to forwarding
Oct 20 22:35:26 STP: MSTI0: New root on port 2, root path cost is 20000
Oct 20 22:35:27 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 21 00:29:55 STP: set port 1 to discarding
Oct 21 00:29:55 STP: set port 1 to learning
Oct 21 00:29:55 STP: set port 1 to forwarding
Oct 21 01:19:01 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 21 01:19:08 STP: set port 6 to discarding
Oct 21 01:19:08 STP: set port 6 to learning
Oct 21 01:19:08 STP: set port 6 to forwarding
Oct 21 01:19:09 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 21 01:19:18 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 21 01:19:25 STP: MSTI0: New root on port 2, root path cost is 20000
Oct 21 01:19:25 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 21 01:22:01 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 21 01:22:01 STP: set port 1 to discarding
Oct 21 01:22:15 STP: MSTI0: New root on port -11, root path cost is 220000
Oct 21 01:22:16 STP: set port 1 to learning
Oct 21 01:22:16 STP: set port 1 to forwarding
Oct 21 01:22:31 STP: MSTI0: New root on port 2, root path cost is 20000
Oct 21 01:22:32 STP: MSTI0: New root on port -11, root path cost is 220000
KBrownConsulting
Sat Oct 28, 2017 2:57 am
Any thoughts?
KBrownConsulting
Fri Dec 01, 2017 5:19 am
Eric Stern wrote:Seeing the entire log would be helpful.
Any follow up on this?
Eric Stern
Fri Dec 01, 2017 11:45 am
This is fixed in 1.4.8
KBrownConsulting
Mon Dec 04, 2017 12:45 am
Thanks!
