MST Root Port Question
socraticmethod
Sat Sep 30, 2017 4:11 pm
This isn't necessarily any issue, I'm just trying to figure out a couple of things about the following log entry.
Code: Select all
Sep 30 15:04:24 STP: MSTI0: New root on port 1, root path cost is 20000
1) Why is MST enabled when the switch is running RSTP?
2) Why is MST selecting root port 1 when there is nothing patched into it?
3) Is this an issue?
See below screenshot and snippet from my Syslog.
Code: Select all
Sep 30 14:53:45 UI: Syslog_Log_Logins: changed from 'Disabled' to 'Enabled'
Sep 30 14:53:48 dropbear[1421]: Premature exit: Terminated by signal
Sep 30 14:53:48 dropbear[547]: Running in background
Sep 30 15:04:12 UI: Configuration changed by admin (10.0.0.77)
Sep 30 15:04:12 UI: Port 11 Name: changed from 'Media Converter' to 'Artist Relations DL'
Sep 30 15:04:22 monitor: restarting vtss_appl
Sep 30 15:04:23 STP: set port 11 to discarding
Sep 30 15:04:23 STP: set port 12 to discarding
Sep 30 15:04:24 STP: set port 11 to learning
Sep 30 15:04:24 STP: set port 11 to forwarding
Sep 30 15:04:24 STP: set port 12 to learning
Sep 30 15:04:24 STP: set port 12 to forwarding
Eric Stern
Been thanked: 130 times
Re: MST Root Port Question
Tue Oct 03, 2017 1:11 pm
I'd need to see your STP tab.
socraticmethod
Sat Oct 07, 2017 9:13 pm
Thanks for the response. What is the reason for choosing port 1 as root when there's nothing patched into it?
Eric Stern
Tue Oct 10, 2017 3:15 pm
I tried to duplicate this in my lab but couldn't. Just some kind of fluke I think. Obviously root didn't stay on port 1 as your screenshot shows root on port 12. If you notice it happen again I can look into it more, but I don't think its anything to worry about.
socraticmethod
Fri Oct 13, 2017 10:43 pm
Thanks for the reply. I've seen this log on multiple switches with nothing plugged into Port 1. It doesn't seem to be causing an issue, but I was curious and wanted to see what y'all though. Here's a screen shot from another switch.
