Issues with VLANs
ftips
Issues with VLANs
Thu Sep 21, 2017 5:34 pm
We have been running multiple vlans on netonix switches very successfully; till recently. We have installed three different 12-250-AC switches over the last couple of weeks and we have two different anomolies appearing. The 1st is adding a VLAN 35 and tagging it to a port that has an untagged vlan running on it. The issue is after adding this VLAN, we start experiencing massive packet loss on both VLANS. If we shut off the vlan, the packet loss on the original vlan goes away.
The 2nd issue is when we have three or more vlans on a switch, when using the switch as a midspan injector the multiple backhauls, the last vlan added will not pass traffic to the backhaul. In all cases, the backhaul that wont work is a Mimosa B5c. If we turn power off to radio, use a poe injector and plug data side of injector into the port that was formerly providing power, the connection works.
Re: Issues with VLANs
Thu Sep 21, 2017 5:38 pm
Please make a separate post for each issue below in this thread.
Post up the descriptions of each issue with each switch's screen grabs of the config TABS: Status, Ports, VLANs, Device/Configuration, and Device/Status
Fri Sep 22, 2017 9:31 am
First issue seem to be a network look. A schema of your network would help.
