Failed Authentication using SSH with RADIUS
- rwa@mst.edu
I am having an issue using SSH with RADIUS authentication running version 1.4.7 or 1.4.8RC10. I can access the switch using HTTPS with a username authenticated by RADIUS but cannot access the same device with the same username via SSH. The log reports that authentication failed. I have the "Allow Passwords" option enabled.
Eric Stern - Employee
- Been thanked: 130 times
Re: Failed Authentication using SSH with RADIUS
Just tested with 1.4.8rc10, seems to work fine. Do you have any strange characters in the username or password?
- rwa@mst.edu
There is a $ in the password in question. The username is all alphabetic characters.
- rwa@mst.edu
And I just found if I escape that character with \ the login is successful.
This will be fixed in 1.4.8rc11
