24V is out of Range, WS-8-150-AC, 1.4.8rc5, Board Rev F
ITSystem
Mon Sep 11, 2017 2:44 am
We have a switch that is reporting loads of "24V is out of range" and also many STP changes on one 24V radio, so I assume that link may also have some disruption.
Port 6 is powering one "Rocket 5AC PTMP". The other PoE on this switch is; Port 4: "UniFi AC Pro 48V", Port:7 "Rocket 5AC PTP 24V" - but they don't report any problem from what I've seen.
If it is of any relevance, then I can say that this switch has replaced RMA#: 1072
Tech notes:
Date of MFG: 7/13/2016
3.3v issue
Added cap/ground mods
Upgraded/defaulted firmware
Firmware: 1.4.8rc7
Fully tested GOOD
Below is some of the log from the new switch:
Sep 9 13:53:50 STP: set port 6 to learning
Sep 9 13:53:50 STP: set port 6 to forwarding
Sep 9 14:13:00 STP: set port 6 to discarding
Sep 9 14:13:00 STP: set port 6 to learning
Sep 9 14:13:00 STP: set port 6 to forwarding
Sep 9 14:16:52 STP: set port 6 to discarding
Sep 9 14:16:52 STP: set port 6 to learning
Sep 9 14:16:52 STP: set port 6 to forwarding
Sep 9 14:30:37 STP: set port 6 to discarding
Sep 9 14:30:37 STP: set port 6 to learning
Sep 9 14:30:37 STP: set port 6 to forwarding
Sep 9 14:37:20 STP: set port 6 to discarding
Sep 9 14:37:20 STP: set port 6 to learning
Sep 9 14:37:20 STP: set port 6 to forwarding
Sep 9 14:38:11 switch[1364]: 24V is out of range (22.7V)
Sep 9 14:45:58 STP: set port 6 to discarding
Sep 9 14:45:58 STP: set port 6 to learning
Sep 9 14:45:58 STP: set port 6 to forwarding
Sep 9 14:54:05 STP: set port 6 to discarding
Sep 9 14:54:05 STP: set port 6 to learning
Sep 9 14:54:05 STP: set port 6 to forwarding
Sep 9 14:54:22 STP: set port 6 to discarding
Sep 9 14:54:22 STP: set port 6 to learning
Sep 9 14:54:22 STP: set port 6 to forwarding
Sep 9 15:06:15 switch[1364]: 24V is out of range (22.7V)
Sep 9 15:16:11 switch[1364]: 24V is out of range (22.8V)
Sep 9 15:46:43 switch[1364]: 24V is out of range (22.6V)
Sep 9 15:46:49 STP: set port 6 to discarding
Sep 9 15:46:49 STP: set port 6 to learning
Sep 9 15:46:49 STP: set port 6 to forwarding
Sep 9 16:11:21 switch[1364]: 24V is out of range (22.5V)
Sep 9 16:16:24 STP: set port 6 to discarding
Sep 9 16:16:24 STP: set port 6 to learning
Sep 9 16:16:24 STP: set port 6 to forwarding
Sep 9 16:22:25 STP: set port 6 to discarding
Sep 9 16:22:25 STP: set port 6 to learning
Sep 9 16:22:25 STP: set port 6 to forwarding
Sep 9 16:25:20 STP: set port 6 to discarding
Sep 9 16:25:20 STP: set port 6 to learning
Sep 9 16:25:20 STP: set port 6 to forwarding
Sep 9 16:37:19 switch[1364]: 24V is out of range (22.7V)
Sep 9 16:39:34 STP: set port 6 to discarding
Sep 9 16:39:34 STP: set port 6 to learning
Sep 9 16:39:34 STP: set port 6 to forwarding
Sep 9 17:11:30 STP: set port 6 to discarding
Sep 9 17:11:30 STP: set port 6 to learning
Sep 9 17:11:30 STP: set port 6 to forwarding
Sep 9 17:13:36 STP: set port 6 to discarding
Sep 9 17:13:36 STP: set port 6 to learning
Sep 9 17:13:36 STP: set port 6 to forwarding
Sep 9 17:17:57 switch[1364]: 24V is out of range (22.8V)
Sep 9 17:22:38 STP: set port 6 to discarding
Sep 9 17:22:38 STP: set port 6 to learning
Sep 9 17:22:38 STP: set port 6 to forwarding
Sep 9 17:30:06 STP: set port 6 to discarding
Sep 9 17:30:06 STP: set port 6 to learning
Sep 9 17:30:06 STP: set port 6 to forwarding
Sep 9 17:30:16 STP: set port 6 to discarding
Sep 9 17:30:16 STP: set port 6 to learning
Sep 9 17:30:16 STP: set port 6 to forwarding
Sep 9 17:31:51 STP: set port 6 to discarding
Sep 9 17:31:51 STP: set port 6 to learning
Sep 9 17:31:51 STP: set port 6 to forwarding
Sep 9 17:32:44 STP: set port 6 to discarding
Sep 9 17:32:44 STP: set port 6 to learning
Sep 9 17:32:44 STP: set port 6 to forwarding
Sep 9 17:34:18 STP: set port 6 to discarding
Sep 9 17:34:18 STP: set port 6 to learning
Sep 9 17:34:18 STP: set port 6 to forwarding
Sep 9 17:35:31 STP: set port 6 to discarding
Sep 9 17:35:31 STP: set port 6 to learning
Sep 9 17:35:31 STP: set port 6 to forwarding
Sep 9 17:40:13 switch[1364]: 24V is out of range (22.7V)
Sep 9 18:07:12 STP: set port 6 to discarding
Sep 9 18:07:12 STP: set port 6 to learning
Sep 9 18:07:12 STP: set port 6 to forwarding
Sep 9 18:12:48 STP: set port 6 to discarding
Sep 9 18:12:48 STP: set port 6 to learning
Sep 9 18:12:48 STP: set port 6 to forwarding
Sep 9 18:12:58 STP: set port 6 to discarding
Sep 9 18:12:58 STP: set port 6 to learning
Sep 9 18:12:58 STP: set port 6 to forwarding
Sep 9 18:13:02 switch[1364]: 24V is out of range (22.7V)
Sep 9 18:19:18 switch[1364]: 24V is out of range (22.7V)
Sep 9 18:21:20 STP: set port 6 to discarding
Sep 9 18:21:20 STP: set port 6 to learning
Sep 9 18:21:20 STP: set port 6 to forwarding
Sep 9 18:23:39 STP: set port 6 to discarding
Sep 9 18:23:39 STP: set port 6 to learning
Sep 9 18:23:39 STP: set port 6 to forwarding
Sep 9 18:29:27 STP: set port 6 to discarding
Sep 9 18:29:27 STP: set port 6 to learning
Sep 9 18:29:27 STP: set port 6 to forwarding
Sep 9 18:40:57 switch[1364]: 24V is out of range (22.6V)
Sep 9 18:46:09 STP: set port 6 to discarding
Sep 9 18:46:09 STP: set port 6 to learning
Sep 9 18:46:09 STP: set port 6 to forwarding
Sep 9 18:51:55 STP: set port 6 to discarding
Sep 9 18:51:55 STP: set port 6 to learning
Sep 9 18:51:55 STP: set port 6 to forwarding
Sep 9 19:08:32 switch[1364]: 24V is out of range (22.8V)
Sep 9 19:08:43 STP: set port 6 to discarding
Sep 9 19:08:43 STP: set port 6 to learning
Sep 9 19:08:43 STP: set port 6 to forwarding
Sep 9 19:12:40 STP: set port 6 to discarding
Sep 9 19:12:40 STP: set port 6 to learning
Sep 9 19:12:40 STP: set port 6 to forwarding
Sep 9 19:15:23 STP: set port 6 to discarding
Sep 9 19:15:23 STP: set port 6 to learning
Sep 9 19:15:23 STP: set port 6 to forwarding
Sep 9 19:18:59 switch[1364]: 24V is out of range (22.7V)
Sep 9 19:21:56 switch[1364]: 24V is out of range (22.6V)
Sep 9 19:24:32 STP: set port 6 to discarding
Sep 9 19:24:32 STP: set port 6 to learning
Sep 9 19:24:32 STP: set port 6 to forwarding
Sep 9 19:33:11 STP: set port 6 to discarding
Sep 9 19:33:11 STP: set port 6 to learning
Sep 9 19:33:11 STP: set port 6 to forwarding
Sep 9 19:35:08 switch[1364]: 24V is out of range (22.6V)
Sep 9 19:38:53 STP: set port 6 to discarding
Sep 9 19:38:53 STP: set port 6 to learning
Sep 9 19:38:53 STP: set port 6 to forwarding
Sep 9 19:57:19 STP: set port 6 to discarding
Sep 9 19:57:19 STP: set port 6 to learning
Sep 9 19:57:19 STP: set port 6 to forwarding
Sep 9 20:00:16 switch[1364]: 24V is out of range (22.5V)
Sep 9 20:01:21 switch[1364]: 24V is out of range (22.7V)
Sep 9 20:35:19 STP: set port 6 to discarding
Sep 9 20:35:19 STP: set port 6 to learning
Sep 9 20:35:19 STP: set port 6 to forwarding
Sep 9 20:37:54 STP: set port 6 to discarding
Sep 9 20:37:54 STP: set port 6 to learning
Sep 9 20:37:55 STP: set port 6 to forwarding
Sep 9 20:39:59 STP: set port 6 to discarding
Sep 9 20:39:59 STP: set port 6 to learning
Sep 9 20:39:59 STP: set port 6 to forwarding
Sep 9 20:48:36 switch[1364]: 24V is out of range (22.4V)
Sep 9 21:01:47 STP: set port 6 to discarding
Sep 9 21:01:47 STP: set port 6 to learning
Sep 9 21:01:47 STP: set port 6 to forwarding
Sep 9 21:04:51 switch[1364]: 24V is out of range (22.6V)
Sep 9 21:06:58 switch[1364]: 24V is out of range (22.8V)
Sep 9 21:10:06 switch[1364]: 24V is out of range (22.8V)
Sep 9 21:25:15 STP: set port 6 to discarding
Sep 9 21:25:15 STP: set port 6 to learning
Sep 9 21:25:15 STP: set port 6 to forwarding
Sep 9 21:26:24 STP: set port 6 to discarding
Sep 9 21:26:24 STP: set port 6 to learning
Sep 9 21:26:24 STP: set port 6 to forwarding
Sep 9 21:28:17 switch[1364]: 24V is out of range (22.5V)
Sep 9 21:31:26 STP: set port 6 to discarding
Sep 9 21:31:26 STP: set port 6 to learning
Sep 9 21:31:26 STP: set port 6 to forwarding
Sep 9 21:39:21 STP: set port 6 to discarding
Sep 9 21:39:21 STP: set port 6 to learning
Sep 9 21:39:21 STP: set port 6 to forwarding
Sep 9 21:41:32 STP: set port 6 to discarding
Sep 9 21:41:32 STP: set port 6 to learning
Sep 9 21:41:32 STP: set port 6 to forwarding
Sep 9 21:45:19 STP: set port 6 to discarding
Sep 9 21:45:19 STP: set port 6 to learning
Sep 9 21:45:19 STP: set port 6 to forwarding
Sep 9 22:01:47 switch[1364]: 24V is out of range (22.7V)
Sep 9 22:09:25 STP: set port 6 to discarding
Sep 9 22:09:25 STP: set port 6 to learning
Sep 9 22:09:25 STP: set port 6 to forwarding
Sep 9 22:27:56 switch[1364]: 24V is out of range (22.7V)
Sep 9 22:32:06 STP: set port 6 to discarding
Sep 9 22:32:06 STP: set port 6 to learning
Sep 9 22:32:06 STP: set port 6 to forwarding
Sep 9 22:33:36 switch[1364]: 24V is out of range (22.8V)
Sep 9 22:36:28 STP: set port 6 to discarding
Sep 9 22:36:28 STP: set port 6 to learning
Sep 9 22:36:28 STP: set port 6 to forwarding
Sep 9 22:37:03 STP: set port 6 to discarding
Sep 9 22:37:03 STP: set port 6 to learning
Sep 9 22:37:03 STP: set port 6 to forwarding
Sep 9 22:51:58 STP: set port 6 to discarding
Sep 9 22:51:58 STP: set port 6 to learning
Sep 9 22:51:58 STP: set port 6 to forwarding
Sep 9 22:57:13 STP: set port 6 to discarding
Sep 9 22:57:13 STP: set port 6 to learning
Sep 9 22:57:13 STP: set port 6 to forwarding
Sep 9 23:09:10 switch[1364]: 24V is out of range (22.5V)
Sep 9 23:20:21 STP: set port 6 to discarding
Sep 9 23:20:21 STP: set port 6 to learning
Sep 9 23:20:21 STP: set port 6 to forwarding
Sep 9 23:28:44 STP: set port 6 to discarding
Sep 9 23:28:44 STP: set port 6 to learning
Sep 9 23:28:44 STP: set port 6 to forwarding
Sep 10 00:43:21 switch[1364]: 24V is out of range (22.7V)
Sep 10 00:49:33 STP: set port 6 to discarding
Sep 10 00:49:33 STP: set port 6 to learning
Sep 10 00:49:33 STP: set port 6 to forwarding
Sep 10 01:07:45 switch[1364]: 24V is out of range (22.6V)
Sep 10 01:22:49 STP: set port 6 to discarding
Sep 10 01:22:49 STP: set port 6 to learning
Sep 10 01:22:49 STP: set port 6 to forwarding
Sep 10 01:49:06 switch[1364]: 24V is out of range (22.7V)
Sep 10 02:36:08 switch[1364]: 24V is out of range (22.7V)
Sep 10 03:11:59 switch[1364]: 24V is out of range (22.8V)
Sep 10 04:02:08 switch[1364]: 24V is out of range (22.7V)
Sep 10 04:11:22 switch[1364]: 24V is out of range (22.5V)
Sep 10 04:23:57 STP: set port 6 to discarding
Sep 10 04:23:57 STP: set port 6 to learning
Sep 10 04:23:57 STP: set port 6 to forwarding
Sep 10 04:45:16 switch[1364]: 24V is out of range (22.7V)
Sep 10 04:45:45 switch[1364]: 24V is out of range (22.6V)
Sep 10 06:37:59 switch[1364]: 24V is out of range (22.8V)
Sep 10 06:46:18 switch[1364]: 24V is out of range (22.8V)
Sep 10 06:51:19 switch[1364]: 24V is out of range (22.7V)
Sep 10 06:51:56 switch[1364]: 24V is out of range (22.6V)
Sep 10 07:32:09 switch[1364]: 24V is out of range (22.8V)
Sep 10 08:13:59 STP: set port 6 to discarding
Sep 10 08:13:59 STP: set port 6 to learning
Sep 10 08:13:59 STP: set port 6 to forwarding
Sep 10 08:22:52 STP: set port 6 to discarding
Sep 10 08:22:52 STP: set port 6 to learning
Sep 10 08:22:52 STP: set port 6 to forwarding
Sep 10 08:33:03 switch[1364]: 24V is out of range (22.7V)
Sep 10 08:48:56 switch[1364]: 24V is out of range (22.7V)
Sep 10 09:02:52 switch[1364]: 24V is out of range (22.6V)
Sep 10 09:42:08 STP: set port 6 to discarding
Sep 10 09:42:08 STP: set port 6 to learning
Sep 10 09:42:08 STP: set port 6 to forwarding
Sep 10 09:51:59 STP: set port 6 to discarding
Sep 10 09:51:59 STP: set port 6 to learning
Sep 10 09:51:59 STP: set port 6 to forwarding
Sep 10 09:52:44 STP: set port 6 to discarding
Sep 10 09:52:44 STP: set port 6 to learning
Sep 10 09:52:44 STP: set port 6 to forwarding
Sep 10 10:06:26 switch[1364]: 24V is out of range (22.7V)
Sep 10 10:55:28 switch[1364]: 24V is out of range (22.7V)
Sep 10 10:55:34 switch[1364]: 24V is out of range (22.8V)
Sep 10 11:04:29 switch[1364]: 24V is out of range (22.6V)
Sep 10 11:12:51 STP: set port 6 to discarding
Sep 10 11:12:51 STP: set port 6 to learning
Sep 10 11:12:51 STP: set port 6 to forwarding
Sep 10 11:22:37 switch[1364]: 24V is out of range (22.8V)
Sep 10 11:41:07 STP: set port 6 to discarding
Sep 10 11:41:07 STP: set port 6 to learning
Sep 10 11:41:07 STP: set port 6 to forwarding
Sep 10 12:02:11 STP: set port 6 to discarding
Sep 10 12:02:11 STP: set port 6 to learning
Sep 10 12:02:11 STP: set port 6 to forwarding
Sep 10 12:04:26 STP: set port 6 to discarding
Sep 10 12:04:26 STP: set port 6 to learning
Sep 10 12:04:26 STP: set port 6 to forwarding
Sep 10 12:20:30 STP: set port 6 to discarding
Sep 10 12:20:30 STP: set port 6 to learning
Sep 10 12:20:30 STP: set port 6 to forwarding
Sep 10 12:30:13 STP: set port 6 to discarding
Sep 10 12:30:13 STP: set port 6 to learning
Sep 10 12:30:13 STP: set port 6 to forwarding
Sep 10 12:32:38 STP: set port 6 to discarding
Sep 10 12:32:38 STP: set port 6 to learning
Sep 10 12:32:38 STP: set port 6 to forwarding
Sep 10 12:33:35 STP: set port 6 to discarding
Sep 10 12:33:35 STP: set port 6 to learning
Sep 10 12:33:35 STP: set port 6 to forwarding
Sep 10 12:35:34 STP: set port 6 to discarding
Sep 10 12:35:34 STP: set port 6 to learning
Sep 10 12:35:34 STP: set port 6 to forwarding
Sep 10 12:47:46 STP: set port 6 to discarding
Sep 10 12:47:46 STP: set port 6 to learning
Sep 10 12:47:46 STP: set port 6 to forwarding
Sep 10 12:53:07 STP: set port 6 to discarding
Sep 10 12:53:07 STP: set port 6 to learning
Sep 10 12:53:07 STP: set port 6 to forwarding
Sep 10 13:14:20 STP: set port 6 to discarding
Sep 10 13:14:20 STP: set port 6 to learning
Sep 10 13:14:20 STP: set port 6 to forwarding
Sep 10 13:28:34 switch[1364]: 24V is out of range (22.6V)
Sep 10 13:37:48 switch[1364]: 24V is out of range (22.8V)
Sep 10 14:12:45 switch[1364]: 24V is out of range (22.7V)
Sep 10 14:18:06 switch[1364]: 24V is out of range (22.8V)
Sep 10 14:40:55 STP: set port 6 to discarding
Sep 10 14:40:55 STP: set port 6 to learning
Sep 10 14:40:55 STP: set port 6 to forwarding
Sep 10 15:12:51 switch[1364]: 24V is out of range (22.7V)
Sep 10 15:33:14 STP: set port 6 to discarding
Sep 10 15:33:14 STP: set port 6 to learning
Sep 10 15:33:14 STP: set port 6 to forwarding
Sep 10 16:11:09 STP: set port 6 to discarding
Sep 10 16:11:09 STP: set port 6 to learning
Sep 10 16:11:09 STP: set port 6 to forwarding
Sep 10 16:23:28 STP: set port 6 to discarding
Sep 10 16:23:28 STP: set port 6 to learning
Sep 10 16:23:28 STP: set port 6 to forwarding
Sep 10 16:25:38 switch[1364]: 24V is out of range (22.7V)
Sep 10 16:29:07 STP: set port 6 to discarding
Sep 10 16:29:07 STP: set port 6 to learning
Sep 10 16:29:07 STP: set port 6 to forwarding
Sep 10 16:29:25 STP: set port 6 to discarding
Sep 10 16:29:25 STP: set port 6 to learning
Sep 10 16:29:25 STP: set port 6 to forwarding
Sep 10 16:45:31 switch[1364]: 24V is out of range (22.7V)
Sep 10 17:02:43 STP: set port 6 to discarding
Sep 10 17:02:43 STP: set port 6 to learning
Sep 10 17:02:43 STP: set port 6 to forwarding
Sep 10 17:33:05 switch[1364]: 24V is out of range (22.6V)
Sep 10 17:36:05 switch[1364]: 24V is out of range (22.7V)
Sep 10 17:47:13 STP: set port 6 to discarding
Sep 10 17:47:13 STP: set port 6 to learning
Sep 10 17:47:13 STP: set port 6 to forwarding
Sep 10 18:11:35 switch[1364]: 24V is out of range (22.7V)
Sep 10 18:21:17 switch[1364]: 24V is out of range (22.7V)
Sep 10 18:33:13 switch[1364]: 24V is out of range (22.6V)
Sep 10 18:48:41 STP: set port 6 to discarding
Sep 10 18:48:41 STP: set port 6 to learning
Sep 10 18:48:41 STP: set port 6 to forwarding
Sep 10 18:52:45 STP: set port 6 to discarding
Sep 10 18:52:45 STP: set port 6 to learning
Sep 10 18:52:45 STP: set port 6 to forwarding
Sep 10 18:57:10 switch[1364]: 24V is out of range (22.7V)
Sep 10 19:07:01 STP: set port 6 to discarding
Sep 10 19:07:02 STP: set port 6 to learning
Sep 10 19:07:02 STP: set port 6 to forwarding
Sep 10 19:15:13 STP: set port 6 to discarding
Sep 10 19:15:13 STP: set port 6 to learning
Sep 10 19:15:13 STP: set port 6 to forwarding
Sep 10 19:30:34 STP: set port 6 to discarding
Sep 10 19:30:34 STP: set port 6 to learning
Sep 10 19:30:34 STP: set port 6 to forwarding
Sep 10 19:34:43 switch[1364]: 24V is out of range (22.7V)
Sep 10 19:42:16 switch[1364]: 24V is out of range (22.7V)
Sep 10 19:48:54 STP: set port 6 to discarding
Sep 10 19:48:54 STP: set port 6 to learning
Sep 10 19:48:54 STP: set port 6 to forwarding
Sep 10 19:53:15 STP: set port 6 to discarding
Sep 10 19:53:15 STP: set port 6 to learning
Sep 10 19:53:15 STP: set port 6 to forwarding
Sep 10 20:01:21 switch[1364]: 24V is out of range (22.7V)
Sep 10 20:03:25 switch[1364]: 24V is out of range (22.7V)
Sep 10 20:07:57 switch[1364]: 24V is out of range (22.7V)
Sep 10 20:08:04 switch[1364]: 24V is out of range (22.8V)
Sep 10 20:33:19 switch[1364]: 24V is out of range (22.6V)
Sep 10 20:56:36 STP: set port 6 to discarding
Sep 10 20:56:36 STP: set port 6 to learning
Sep 10 20:56:36 STP: set port 6 to forwarding
Sep 10 21:15:34 STP: set port 6 to discarding
Sep 10 21:15:34 STP: set port 6 to learning
Sep 10 21:15:34 STP: set port 6 to forwarding
Sep 10 21:16:26 switch[1364]: 24V is out of range (22.7V)
Sep 10 21:16:36 switch[1364]: 24V is out of range (22.7V)
Sep 10 21:18:10 switch[1364]: 24V is out of range (22.7V)
Sep 10 21:18:43 STP: set port 6 to discarding
Sep 10 21:18:43 STP: set port 6 to learning
Sep 10 21:18:43 STP: set port 6 to forwarding
Sep 10 21:21:30 switch[1364]: 24V is out of range (22.6V)
Sep 10 21:22:25 STP: set port 6 to discarding
Sep 10 21:22:25 STP: set port 6 to learning
Sep 10 21:22:25 STP: set port 6 to forwarding
Sep 10 21:28:18 STP: set port 6 to discarding
Sep 10 21:28:18 STP: set port 6 to learning
Sep 10 21:28:18 STP: set port 6 to forwarding
Sep 10 21:29:39 STP: set port 6 to discarding
Sep 10 21:29:39 STP: set port 6 to learning
Sep 10 21:29:39 STP: set port 6 to forwarding
Sep 10 21:53:53 STP: set port 6 to discarding
Sep 10 21:53:53 STP: set port 6 to learning
Sep 10 21:53:53 STP: set port 6 to forwarding
Sep 10 21:55:08 STP: set port 6 to discarding
Sep 10 21:55:08 STP: set port 6 to learning
Sep 10 21:55:08 STP: set port 6 to forwarding
Sep 10 21:59:53 STP: set port 6 to discarding
Sep 10 21:59:53 STP: set port 6 to learning
Sep 10 21:59:53 STP: set port 6 to forwarding
Sep 10 22:09:01 STP: set port 6 to discarding
Sep 10 22:09:01 STP: set port 6 to learning
Sep 10 22:09:01 STP: set port 6 to forwarding
Sep 10 22:12:05 switch[1364]: 24V is out of range (22.7V)
Sep 10 22:19:48 STP: set port 6 to discarding
Sep 10 22:19:48 STP: set port 6 to learning
Sep 10 22:19:48 STP: set port 6 to forwarding
Sep 10 22:41:15 STP: set port 6 to discarding
Sep 10 22:41:15 STP: set port 6 to learning
Sep 10 22:41:15 STP: set port 6 to forwarding
Sep 10 22:50:37 STP: set port 6 to discarding
Sep 10 22:50:37 STP: set port 6 to learning
Sep 10 22:50:37 STP: set port 6 to forwarding
Sep 10 23:02:13 STP: set port 6 to discarding
Sep 10 23:02:13 STP: set port 6 to learning
Sep 10 23:02:13 STP: set port 6 to forwarding
Sep 10 23:13:27 switch[1364]: 24V is out of range (22.6V)
Sep 10 23:53:21 STP: set port 6 to discarding
Sep 10 23:53:21 STP: set port 6 to learning
Sep 10 23:53:21 STP: set port 6 to forwarding
Sep 10 23:56:11 switch[1364]: 24V is out of range (22.5V)
Sep 11 00:02:38 STP: set port 6 to discarding
Sep 11 00:02:39 STP: set port 6 to learning
Sep 11 00:02:39 STP: set port 6 to forwarding
Sep 11 00:03:35 STP: set port 6 to discarding
Sep 11 00:03:36 STP: set port 6 to learning
Sep 11 00:03:36 STP: set port 6 to forwarding
Sep 11 00:03:53 switch[1364]: 24V is out of range (22.6V)
Sep 11 00:07:25 switch[1364]: 24V is out of range (22.7V)
Sep 11 00:13:46 STP: set port 6 to discarding
Sep 11 00:13:46 STP: set port 6 to learning
Sep 11 00:13:46 STP: set port 6 to forwarding
Sep 11 00:14:50 switch[1364]: 24V is out of range (22.4V)
Sep 11 00:22:33 switch[1364]: 24V is out of range (22.7V)
Sep 11 01:14:07 STP: set port 6 to discarding
Sep 11 01:14:07 STP: set port 6 to learning
Sep 11 01:14:07 STP: set port 6 to forwarding
Sep 11 01:18:07 switch[1364]: 24V is out of range (22.7V)
Sep 11 01:28:16 switch[1364]: 24V is out of range (22.7V)
Sep 11 01:41:40 switch[1364]: 24V is out of range (22.6V)
Sep 11 01:46:43 switch[1364]: 24V is out of range (22.7V)
Sep 11 02:11:28 switch[1364]: 24V is out of range (22.7V)
Sep 11 02:28:25 switch[1364]: 24V is out of range (22.7V)
Sep 11 03:03:06 switch[1364]: 24V is out of range (22.7V)
Sep 11 03:11:48 switch[1364]: 24V is out of range (22.8V)
Sep 11 04:06:38 switch[1364]: 24V is out of range (22.7V)
Sep 11 04:15:18 switch[1364]: 24V is out of range (22.7V)
Sep 11 04:28:22 switch[1364]: 24V is out of range (22.5V)
Sep 11 04:44:40 switch[1364]: 24V is out of range (22.8V)
Sep 11 04:59:22 switch[1364]: 24V is out of range (22.8V)
Sep 11 06:07:00 switch[1364]: 24V is out of range (22.7V)
Sep 11 06:48:08 switch[1364]: 24V is out of range (22.7V)
Sep 11 06:51:31 switch[1364]: 24V is out of range (22.6V)
Sep 11 07:28:48 switch[1364]: 24V is out of range (22.7V)
Sep 11 07:50:50 switch[1364]: 24V is out of range (22.5V)
Sep 11 07:53:24 STP: set port 6 to discarding
Sep 11 07:53:24 STP: set port 6 to learning
Sep 11 07:53:24 STP: set port 6 to forwarding
Re: 24V is out of Range, WS-8-150-AC, 1.4.8rc5, Board Rev F
Mon Sep 11, 2017 8:27 am
STP always discarding, learning and forwarding mean ethernet disconnection. Does the rocket reboot (check uptime) ?
Mon Sep 11, 2017 9:46 am
RMA#: 1072
Tech notes:
3.3v issue
Firmware: 1.4.8rc7
Fully tested GOOD
No the switch was not replaced, we repaired it or we thought we did.
The 24V out of range would not be causing your STP issue unless the radios are rebooting which Mike asked you to check.
Whatever is on Port 6 is flapping for some reason.
Please post up screen grabs of the Status and Device/Status TABs
Tell us what is on every port and what your setup here is.
ITSystem
Mon Sep 18, 2017 8:05 am
You repaired another switch. This switch is the one that I replaces the failing one with some months ago, I now have the repaired one on my desk but I have not opened the ESD bag yet - so that's another story :wink:
The Rocket on port 6 report uptime to be 83+ days
I also checked the MAC table on the switch to verify that the Rocket's MAC is found on port 6, so I'm pretty sure it's connected there and not on another port.
ITSystem
Mon Sep 18, 2017 9:37 am
:idea: So your next question will be if I have restarted the Rocket and what firmware it is running. Good point there, I'll restart it and upgrade it right away!
Mon Sep 18, 2017 12:43 pm
Make sur STP is disable on the bridge of the rocket. Unless exception, STP shouln't be enable on radio.
ITSystem
Tue Sep 19, 2017 2:25 am
STP is (as default) off on the Rocket and all stations. However, there are something like 3 ToughSwitch 5-port after this link. Those are all running v 1.3.5 and have STP enabled. All TS5 are connected to one of the 4 stations and none have any other interconnection with each other.
Port 7 is connected to a Rocket AC PTP, which eventually connects to a total of 4 ToughSwitch 5-port with STP enabled, but port 7 doesn't report any STP changes and have transmitted about twice the amount of data as port 6 - so it's well used.
I'm not sure if it's of any kind of relevance, but I did notice that port 7 had chosen Flow Control (auto) enabled but port 6 had it (auto) disabled. I upgraded the firmware on the port 7 Rocket PTP but it's still the same.
This is the log since I've upgraded the Rocket AC PTMP on port 6, and it's 4 NanoBeam stations, to XC.v8.3.2.
Sep 18 15:56:07 STP: set port 6 to discarding
Sep 18 15:56:07 STP: set port 6 to learning
Sep 18 15:56:07 STP: set port 6 to forwarding
Sep 18 15:58:04 STP: set port 6 to discarding
Sep 18 15:58:04 STP: set port 6 to learning
Sep 18 15:58:04 STP: set port 6 to forwarding
Sep 18 15:59:32 switch[1364]: 24V is out of range (22.8V)
Sep 18 16:06:33 switch[1364]: 24V is out of range (22.7V)
Sep 18 16:15:08 switch[1364]: 24V is out of range (22.8V)
Sep 18 16:32:26 switch[1364]: 24V is out of range (22.8V)
Sep 18 16:35:54 STP: set port 6 to discarding
Sep 18 16:35:54 STP: set port 6 to learning
Sep 18 16:35:54 STP: set port 6 to forwarding
Sep 18 16:39:33 STP: set port 6 to discarding
Sep 18 16:39:33 STP: set port 6 to learning
Sep 18 16:39:33 STP: set port 6 to forwarding
Sep 18 16:46:16 STP: set port 6 to discarding
Sep 18 16:46:16 STP: set port 6 to learning
Sep 18 16:46:16 STP: set port 6 to forwarding
Sep 18 16:47:39 STP: set port 6 to discarding
Sep 18 16:47:39 STP: set port 6 to learning
Sep 18 16:47:39 STP: set port 6 to forwarding
Sep 18 16:50:19 STP: set port 6 to discarding
Sep 18 16:50:19 STP: set port 6 to learning
Sep 18 16:50:19 STP: set port 6 to forwarding
Sep 18 16:51:10 STP: set port 6 to discarding
Sep 18 16:51:10 STP: set port 6 to learning
Sep 18 16:51:10 STP: set port 6 to forwarding
Sep 18 17:04:47 STP: set port 6 to discarding
Sep 18 17:04:47 STP: set port 6 to learning
Sep 18 17:04:47 STP: set port 6 to forwarding
Sep 18 17:16:19 STP: set port 6 to discarding
Sep 18 17:16:19 STP: set port 6 to learning
Sep 18 17:16:19 STP: set port 6 to forwarding
Sep 18 17:25:32 switch[1364]: 24V is out of range (22.6V)
Sep 18 17:27:43 STP: set port 6 to discarding
Sep 18 17:27:43 STP: set port 6 to learning
Sep 18 17:27:43 STP: set port 6 to forwarding
Sep 18 17:43:26 switch[1364]: 24V is out of range (22.8V)
Sep 18 17:43:32 switch[1364]: 24V is out of range (22.6V)
Sep 18 17:56:34 switch[1364]: 24V is out of range (22.7V)
Sep 18 18:04:34 STP: set port 6 to discarding
Sep 18 18:04:34 STP: set port 6 to learning
Sep 18 18:04:34 STP: set port 6 to forwarding
Sep 18 18:13:48 STP: set port 6 to discarding
Sep 18 18:13:48 STP: set port 6 to learning
Sep 18 18:13:48 STP: set port 6 to forwarding
Sep 18 18:20:43 switch[1364]: 24V is out of range (22.7V)
Sep 18 18:24:34 switch[1364]: 24V is out of range (22.7V)
Sep 18 18:30:50 switch[1364]: 24V is out of range (22.7V)
Sep 18 18:51:34 switch[1364]: 24V is out of range (22.6V)
Sep 18 19:06:33 STP: set port 6 to discarding
Sep 18 19:06:33 STP: set port 6 to learning
Sep 18 19:06:33 STP: set port 6 to forwarding
Sep 18 19:08:13 STP: set port 6 to discarding
Sep 18 19:08:13 STP: set port 6 to learning
Sep 18 19:08:13 STP: set port 6 to forwarding
Sep 18 19:42:01 STP: set port 6 to discarding
Sep 18 19:42:01 STP: set port 6 to learning
Sep 18 19:42:02 STP: set port 6 to forwarding
Sep 18 19:59:33 STP: set port 6 to discarding
Sep 18 19:59:33 STP: set port 6 to learning
Sep 18 19:59:33 STP: set port 6 to forwarding
Sep 18 20:13:22 STP: set port 6 to discarding
Sep 18 20:13:22 STP: set port 6 to learning
Sep 18 20:13:22 STP: set port 6 to forwarding
Sep 18 20:18:15 STP: set port 6 to discarding
Sep 18 20:18:15 STP: set port 6 to learning
Sep 18 20:18:15 STP: set port 6 to forwarding
Sep 18 20:21:54 switch[1364]: 24V is out of range (22.7V)
Sep 18 20:35:07 STP: set port 6 to discarding
Sep 18 20:35:07 STP: set port 6 to learning
Sep 18 20:35:07 STP: set port 6 to forwarding
Sep 18 20:40:29 switch[1364]: 24V is out of range (22.6V)
Sep 18 20:40:38 STP: set port 6 to discarding
Sep 18 20:40:38 STP: set port 6 to learning
Sep 18 20:40:38 STP: set port 6 to forwarding
Sep 18 20:43:41 STP: set port 6 to discarding
Sep 18 20:43:41 STP: set port 6 to learning
Sep 18 20:43:41 STP: set port 6 to forwarding
Sep 18 20:54:28 switch[1364]: 24V is out of range (22.6V)
Sep 18 20:55:48 STP: set port 6 to discarding
Sep 18 20:55:48 STP: set port 6 to learning
Sep 18 20:55:48 STP: set port 6 to forwarding
Sep 18 21:08:30 switch[1364]: 24V is out of range (22.7V)
Sep 18 21:15:34 STP: set port 6 to discarding
Sep 18 21:15:34 STP: set port 6 to learning
Sep 18 21:15:34 STP: set port 6 to forwarding
Sep 18 21:21:23 STP: set port 6 to discarding
Sep 18 21:21:23 STP: set port 6 to learning
Sep 18 21:21:23 STP: set port 6 to forwarding
Sep 18 21:30:57 switch[1364]: 24V is out of range (22.7V)
Sep 18 21:37:19 STP: set port 6 to discarding
Sep 18 21:37:19 STP: set port 6 to learning
Sep 18 21:37:19 STP: set port 6 to forwarding
Sep 18 21:44:56 STP: set port 6 to discarding
Sep 18 21:44:56 STP: set port 6 to learning
Sep 18 21:44:56 STP: set port 6 to forwarding
Sep 18 21:46:25 STP: set port 6 to discarding
Sep 18 21:46:25 STP: set port 6 to learning
Sep 18 21:46:25 STP: set port 6 to forwarding
Sep 18 21:55:39 switch[1364]: 24V is out of range (22.5V)
Sep 18 22:03:41 switch[1364]: 24V is out of range (22.7V)
Sep 18 22:07:53 STP: set port 6 to discarding
Sep 18 22:07:53 STP: set port 6 to learning
Sep 18 22:07:53 STP: set port 6 to forwarding
Sep 18 22:17:52 STP: set port 6 to discarding
Sep 18 22:17:52 STP: set port 6 to learning
Sep 18 22:17:52 STP: set port 6 to forwarding
Sep 18 22:23:01 switch[1364]: 24V is out of range (22.6V)
Sep 18 22:24:58 switch[1364]: 24V is out of range (22.8V)
Sep 18 22:39:26 STP: set port 6 to discarding
Sep 18 22:39:26 STP: set port 6 to learning
Sep 18 22:39:26 STP: set port 6 to forwarding
Sep 18 22:41:27 STP: set port 6 to discarding
Sep 18 22:41:27 STP: set port 6 to learning
Sep 18 22:41:27 STP: set port 6 to forwarding
Sep 18 23:06:27 switch[1364]: 24V is out of range (22.7V)
Sep 18 23:08:47 STP: set port 6 to discarding
Sep 18 23:08:47 STP: set port 6 to learning
Sep 18 23:08:47 STP: set port 6 to forwarding
Sep 18 23:19:36 STP: set port 6 to discarding
Sep 18 23:19:36 STP: set port 6 to learning
Sep 18 23:19:36 STP: set port 6 to forwarding
Sep 18 23:38:41 switch[1364]: 24V is out of range (22.4V)
Sep 18 23:42:08 STP: set port 6 to discarding
Sep 18 23:42:08 STP: set port 6 to learning
Sep 18 23:42:08 STP: set port 6 to forwarding
Sep 18 23:50:05 STP: set port 6 to discarding
Sep 18 23:50:05 STP: set port 6 to learning
Sep 18 23:50:05 STP: set port 6 to forwarding
Sep 18 23:54:25 STP: set port 6 to discarding
Sep 18 23:54:25 STP: set port 6 to learning
Sep 18 23:54:25 STP: set port 6 to forwarding
Sep 18 23:57:24 switch[1364]: 24V is out of range (22.7V)
Sep 19 00:19:25 STP: set port 6 to discarding
Sep 19 00:19:25 STP: set port 6 to learning
Sep 19 00:19:25 STP: set port 6 to forwarding
Sep 19 01:00:46 switch[1364]: 24V is out of range (22.7V)
Sep 19 01:05:46 switch[1364]: 24V is out of range (22.8V)
Sep 19 01:14:15 switch[1364]: 24V is out of range (22.7V)
Sep 19 01:34:05 switch[1364]: 24V is out of range (22.7V)
Sep 19 01:40:39 switch[1364]: 24V is out of range (22.5V)
Sep 19 02:15:23 switch[1364]: 24V is out of range (22.6V)
Sep 19 02:20:39 STP: set port 6 to discarding
Sep 19 02:20:39 STP: set port 6 to learning
Sep 19 02:20:39 STP: set port 6 to forwarding
Sep 19 02:28:02 switch[1364]: 24V is out of range (22.7V)
Sep 19 02:28:49 switch[1364]: 24V is out of range (22.7V)
Sep 19 02:52:05 switch[1364]: 24V is out of range (22.8V)
Sep 19 03:00:24 STP: set port 6 to discarding
Sep 19 03:00:24 STP: set port 6 to learning
Sep 19 03:00:24 STP: set port 6 to forwarding
Sep 19 03:04:27 STP: set port 6 to discarding
Sep 19 03:04:27 STP: set port 6 to learning
Sep 19 03:04:27 STP: set port 6 to forwarding
Sep 19 03:10:21 switch[1364]: 24V is out of range (22.7V)
Sep 19 03:10:31 switch[1364]: 24V is out of range (22.8V)
Sep 19 03:48:24 STP: set port 6 to discarding
Sep 19 03:48:24 STP: set port 6 to learning
Sep 19 03:48:24 STP: set port 6 to forwarding
Sep 19 04:06:12 switch[1364]: 24V is out of range (22.7V)
Sep 19 04:07:46 switch[1364]: 24V is out of range (22.7V)
Sep 19 04:08:18 STP: set port 6 to discarding
Sep 19 04:08:18 STP: set port 6 to learning
Sep 19 04:08:18 STP: set port 6 to forwarding
Sep 19 04:16:02 switch[1364]: 24V is out of range (22.7V)
Sep 19 04:27:13 switch[1364]: 24V is out of range (22.8V)
Sep 19 04:34:05 switch[1364]: 24V is out of range (22.7V)
Sep 19 04:58:02 switch[1364]: 24V is out of range (22.7V)
Sep 19 05:25:49 STP: set port 6 to discarding
Sep 19 05:25:49 STP: set port 6 to learning
Sep 19 05:25:49 STP: set port 6 to forwarding
Sep 19 05:27:42 switch[1364]: 24V is out of range (22.7V)
Sep 19 05:43:04 switch[1364]: 24V is out of range (22.8V)
Sep 19 05:52:15 switch[1364]: 24V is out of range (22.6V)
Sep 19 06:06:04 STP: set port 6 to discarding
Sep 19 06:06:04 STP: set port 6 to learning
Sep 19 06:06:04 STP: set port 6 to forwarding
Sep 19 06:44:40 switch[1364]: 24V is out of range (22.7V)
Sep 19 06:46:33 switch[1364]: 24V is out of range (22.7V)
Sep 19 07:07:28 STP: set port 6 to discarding
Sep 19 07:07:28 STP: set port 6 to learning
Sep 19 07:07:28 STP: set port 6 to forwarding
Sep 19 07:18:59 STP: set port 6 to discarding
Sep 19 07:18:59 STP: set port 6 to learning
Sep 19 07:18:59 STP: set port 6 to forwarding
Sep 19 07:20:11 switch[1364]: 24V is out of range (22.7V)
Sep 19 07:27:58 STP: set port 6 to discarding
Sep 19 07:27:58 STP: set port 6 to learning
Sep 19 07:27:58 STP: set port 6 to forwarding
Sep 19 07:55:49 switch[1364]: 24V is out of range (22.6V)
ITSystem
Tue Sep 19, 2017 2:32 am
I checked the Rocket PTMP settings and it had flow control off - for some strange reason. I've now enabled it and the switch set it to (auto) on/both. I don't think that should make any difference to the STP problem, but who knows...
The 24V is still a problem, although there are sufficient voltage for all units.
ITSystem
Wed Sep 20, 2017 5:48 am
The problem seem to remain...
Sep 19 08:30:49 switch[1364]: 24V is out of range (22.6V)
Sep 19 08:46:54 switch[1364]: 24V is out of range (22.6V)
Sep 19 08:51:00 switch[1364]: 24V is out of range (22.7V)
Sep 19 08:54:59 switch[1364]: 24V is out of range (22.5V)
Sep 19 09:28:47 switch[1364]: 24V is out of range (22.7V)
Sep 19 09:29:15 switch[1364]: 24V is out of range (22.6V)
Sep 19 09:30:01 switch[1364]: 24V is out of range (22.7V)
Sep 19 09:35:11 switch[1364]: 24V is out of range (22.5V)
Sep 19 10:05:52 switch[1364]: 24V is out of range (22.8V)
Sep 19 10:19:52 switch[1364]: 24V is out of range (22.7V)
Sep 19 11:34:08 switch[1364]: 24V is out of range (22.6V)
Sep 19 11:48:52 switch[1364]: 24V is out of range (22.8V)
Sep 19 12:09:00 switch[1364]: 24V is out of range (22.5V)
Sep 19 12:10:48 switch[1364]: 24V is out of range (22.5V)
Sep 19 12:14:21 STP: set port 6 to discarding
Sep 19 12:14:21 STP: set port 6 to learning
Sep 19 12:14:21 STP: set port 6 to forwarding
Sep 19 12:15:36 switch[1364]: 24V is out of range (22.7V)
Sep 19 12:15:40 STP: set port 6 to discarding
Sep 19 12:15:40 STP: set port 6 to learning
Sep 19 12:15:40 STP: set port 6 to forwarding
Sep 19 12:48:43 switch[1364]: 24V is out of range (22.6V)
Sep 19 12:54:30 STP: set port 6 to discarding
Sep 19 12:54:30 STP: set port 6 to learning
Sep 19 12:54:30 STP: set port 6 to forwarding
Sep 19 13:11:06 STP: set port 6 to discarding
Sep 19 13:11:06 STP: set port 6 to learning
Sep 19 13:11:06 STP: set port 6 to forwarding
Sep 19 13:23:42 STP: set port 6 to discarding
Sep 19 13:23:42 STP: set port 6 to learning
Sep 19 13:23:42 STP: set port 6 to forwarding
Sep 19 13:30:29 STP: set port 6 to discarding
Sep 19 13:30:29 STP: set port 6 to learning
Sep 19 13:30:29 STP: set port 6 to forwarding
Sep 19 13:58:34 STP: set port 6 to discarding
Sep 19 13:58:35 STP: set port 6 to learning
Sep 19 13:58:35 STP: set port 6 to forwarding
Sep 19 14:10:06 switch[1364]: 24V is out of range (22.6V)
Sep 19 14:12:59 switch[1364]: 24V is out of range (22.8V)
Sep 19 14:16:29 switch[1364]: 24V is out of range (22.7V)
Sep 19 14:17:53 switch[1364]: 24V is out of range (22.6V)
Sep 19 14:25:09 switch[1364]: 24V is out of range (22.7V)
Sep 19 14:35:09 STP: set port 6 to discarding
Sep 19 14:35:09 STP: set port 6 to learning
Sep 19 14:35:09 STP: set port 6 to forwarding
Sep 19 14:38:45 STP: set port 6 to discarding
Sep 19 14:38:45 STP: set port 6 to learning
Sep 19 14:38:45 STP: set port 6 to forwarding
Sep 19 14:42:55 STP: set port 6 to discarding
Sep 19 14:42:55 STP: set port 6 to learning
Sep 19 14:42:55 STP: set port 6 to forwarding
Sep 19 14:48:31 switch[1364]: 24V is out of range (22.8V)
Sep 19 14:50:35 STP: set port 6 to discarding
Sep 19 14:50:35 STP: set port 6 to learning
Sep 19 14:50:35 STP: set port 6 to forwarding
Sep 19 14:54:05 switch[1364]: 24V is out of range (22.7V)
Sep 19 14:58:40 STP: set port 6 to discarding
Sep 19 14:58:40 STP: set port 6 to learning
Sep 19 14:58:40 STP: set port 6 to forwarding
Sep 19 14:59:59 switch[1364]: 24V is out of range (22.8V)
Sep 19 15:19:30 STP: set port 6 to discarding
Sep 19 15:19:30 STP: set port 6 to learning
Sep 19 15:19:30 STP: set port 6 to forwarding
Sep 19 15:37:13 STP: set port 6 to discarding
Sep 19 15:37:13 STP: set port 6 to learning
Sep 19 15:37:13 STP: set port 6 to forwarding
Sep 19 15:46:08 switch[1364]: 24V is out of range (22.8V)
Sep 19 15:46:15 switch[1364]: 24V is out of range (22.6V)
Sep 19 15:48:59 STP: set port 6 to discarding
Sep 19 15:48:59 STP: set port 6 to learning
Sep 19 15:48:59 STP: set port 6 to forwarding
Sep 19 16:04:46 STP: set port 6 to discarding
Sep 19 16:04:46 STP: set port 6 to learning
Sep 19 16:04:46 STP: set port 6 to forwarding
Sep 19 16:10:46 STP: set port 6 to discarding
Sep 19 16:10:46 STP: set port 6 to learning
Sep 19 16:10:46 STP: set port 6 to forwarding
Sep 19 16:20:00 switch[1364]: 24V is out of range (22.8V)
Sep 19 16:25:16 switch[1364]: 24V is out of range (22.7V)
Sep 19 16:59:39 switch[1364]: 24V is out of range (22.7V)
Sep 19 17:05:07 STP: set port 6 to discarding
Sep 19 17:05:07 STP: set port 6 to learning
Sep 19 17:05:07 STP: set port 6 to forwarding
Sep 19 17:11:30 STP: set port 6 to discarding
Sep 19 17:11:30 STP: set port 6 to learning
Sep 19 17:11:30 STP: set port 6 to forwarding
Sep 19 17:13:27 STP: set port 6 to discarding
Sep 19 17:13:27 STP: set port 6 to learning
Sep 19 17:13:27 STP: set port 6 to forwarding
Sep 19 17:28:50 STP: set port 6 to discarding
Sep 19 17:28:50 STP: set port 6 to learning
Sep 19 17:28:50 STP: set port 6 to forwarding
Sep 19 17:30:22 switch[1364]: 24V is out of range (22.8V)
Sep 19 17:43:39 switch[1364]: 24V is out of range (22.8V)
Sep 19 17:43:44 STP: set port 6 to discarding
Sep 19 17:43:44 STP: set port 6 to learning
Sep 19 17:43:44 STP: set port 6 to forwarding
Sep 19 18:04:22 STP: set port 6 to discarding
Sep 19 18:04:22 STP: set port 6 to learning
Sep 19 18:04:22 STP: set port 6 to forwarding
Sep 19 18:49:48 switch[1364]: 24V is out of range (22.7V)
Sep 19 18:51:21 switch[1364]: 24V is out of range (22.7V)
Sep 19 19:15:23 STP: set port 6 to discarding
Sep 19 19:15:23 STP: set port 6 to learning
Sep 19 19:15:23 STP: set port 6 to forwarding
Sep 19 19:19:34 switch[1364]: 24V is out of range (22.8V)
Sep 19 19:44:06 switch[1364]: 24V is out of range (22.7V)
Sep 19 19:53:22 STP: set port 6 to discarding
Sep 19 19:53:22 STP: set port 6 to learning
Sep 19 19:53:22 STP: set port 6 to forwarding
Sep 19 19:57:59 switch[1364]: 24V is out of range (22.8V)
Sep 19 20:10:03 switch[1364]: 24V is out of range (22.7V)
Sep 19 20:17:11 switch[1364]: 24V is out of range (22.8V)
Sep 19 20:19:20 switch[1364]: 24V is out of range (22.6V)
Sep 19 20:20:44 switch[1364]: 24V is out of range (22.8V)
Sep 19 20:28:28 STP: set port 6 to discarding
Sep 19 20:28:28 STP: set port 6 to learning
Sep 19 20:28:28 STP: set port 6 to forwarding
Sep 19 20:30:47 STP: set port 6 to discarding
Sep 19 20:30:47 STP: set port 6 to learning
Sep 19 20:30:47 STP: set port 6 to forwarding
Sep 19 20:30:56 switch[1364]: 24V is out of range (22.7V)
Sep 19 20:39:02 STP: set port 6 to discarding
Sep 19 20:39:02 STP: set port 6 to learning
Sep 19 20:39:02 STP: set port 6 to forwarding
Sep 19 20:41:59 STP: set port 6 to discarding
Sep 19 20:41:59 STP: set port 6 to learning
Sep 19 20:41:59 STP: set port 6 to forwarding
Sep 19 20:57:53 STP: set port 6 to discarding
Sep 19 20:57:53 STP: set port 6 to learning
Sep 19 20:57:53 STP: set port 6 to forwarding
Sep 19 21:06:55 STP: set port 6 to discarding
Sep 19 21:06:55 STP: set port 6 to learning
Sep 19 21:06:55 STP: set port 6 to forwarding
Sep 19 21:13:55 switch[1364]: 24V is out of range (22.6V)
Sep 19 21:22:22 STP: set port 6 to discarding
Sep 19 21:22:22 STP: set port 6 to learning
Sep 19 21:22:22 STP: set port 6 to forwarding
Sep 19 21:23:15 switch[1364]: 24V is out of range (22.5V)
Sep 19 21:29:45 STP: set port 6 to discarding
Sep 19 21:29:45 STP: set port 6 to learning
Sep 19 21:29:45 STP: set port 6 to forwarding
Sep 19 21:31:00 STP: set port 6 to discarding
Sep 19 21:31:00 STP: set port 6 to learning
Sep 19 21:31:00 STP: set port 6 to forwarding
Sep 19 21:31:57 STP: set port 6 to discarding
Sep 19 21:31:57 STP: set port 6 to learning
Sep 19 21:31:57 STP: set port 6 to forwarding
Sep 19 21:37:13 STP: set port 6 to discarding
Sep 19 21:37:13 STP: set port 6 to learning
Sep 19 21:37:13 STP: set port 6 to forwarding
Sep 19 21:39:18 STP: set port 6 to discarding
Sep 19 21:39:18 STP: set port 6 to learning
Sep 19 21:39:18 STP: set port 6 to forwarding
Sep 19 21:40:41 STP: set port 6 to discarding
Sep 19 21:40:41 STP: set port 6 to learning
Sep 19 21:40:41 STP: set port 6 to forwarding
Sep 19 21:42:12 STP: set port 6 to discarding
Sep 19 21:42:12 STP: set port 6 to learning
Sep 19 21:42:12 STP: set port 6 to forwarding
Sep 19 21:46:45 STP: set port 6 to discarding
Sep 19 21:46:45 STP: set port 6 to learning
Sep 19 21:46:45 STP: set port 6 to forwarding
Sep 19 21:49:01 switch[1364]: 24V is out of range (22.6V)
Sep 19 21:52:58 STP: set port 6 to discarding
Sep 19 21:52:58 STP: set port 6 to learning
Sep 19 21:52:58 STP: set port 6 to forwarding
Sep 19 21:53:59 switch[1364]: 24V is out of range (22.7V)
Sep 19 21:59:06 STP: set port 6 to discarding
Sep 19 21:59:06 STP: set port 6 to learning
Sep 19 21:59:06 STP: set port 6 to forwarding
Sep 19 22:00:28 STP: set port 6 to discarding
Sep 19 22:00:28 STP: set port 6 to learning
Sep 19 22:00:28 STP: set port 6 to forwarding
Sep 19 22:11:38 STP: set port 6 to discarding
Sep 19 22:11:38 STP: set port 6 to learning
Sep 19 22:11:38 STP: set port 6 to forwarding
Sep 19 22:13:23 STP: set port 6 to discarding
Sep 19 22:13:23 STP: set port 6 to learning
Sep 19 22:13:23 STP: set port 6 to forwarding
Sep 19 22:16:40 STP: set port 6 to discarding
Sep 19 22:16:40 STP: set port 6 to learning
Sep 19 22:16:40 STP: set port 6 to forwarding
Sep 19 22:20:22 STP: set port 6 to discarding
Sep 19 22:20:22 STP: set port 6 to learning
Sep 19 22:20:22 STP: set port 6 to forwarding
Sep 19 22:21:15 STP: set port 6 to discarding
Sep 19 22:21:15 STP: set port 6 to learning
Sep 19 22:21:15 STP: set port 6 to forwarding
Sep 19 22:22:18 switch[1364]: 24V is out of range (22.7V)
Sep 19 22:28:00 STP: set port 6 to discarding
Sep 19 22:28:00 STP: set port 6 to learning
Sep 19 22:28:00 STP: set port 6 to forwarding
Sep 19 22:31:21 STP: set port 6 to discarding
Sep 19 22:31:21 STP: set port 6 to learning
Sep 19 22:31:21 STP: set port 6 to forwarding
Sep 19 22:32:09 switch[1364]: 24V is out of range (22.7V)
Sep 19 22:33:29 switch[1364]: 24V is out of range (22.8V)
Sep 19 22:36:06 STP: set port 6 to discarding
Sep 19 22:36:06 STP: set port 6 to learning
Sep 19 22:36:06 STP: set port 6 to forwarding
Sep 19 22:48:29 STP: set port 6 to discarding
Sep 19 22:48:29 STP: set port 6 to learning
Sep 19 22:48:29 STP: set port 6 to forwarding
Sep 19 22:52:24 switch[1364]: 24V is out of range (22.4V)
Sep 19 23:01:48 STP: set port 6 to discarding
Sep 19 23:01:48 STP: set port 6 to learning
Sep 19 23:01:49 STP: set port 6 to forwarding
Sep 19 23:12:09 switch[1364]: 24V is out of range (22.7V)
Sep 19 23:18:58 STP: set port 6 to discarding
Sep 19 23:18:58 STP: set port 6 to learning
Sep 19 23:18:58 STP: set port 6 to forwarding
Sep 19 23:21:13 STP: set port 6 to discarding
Sep 19 23:21:13 STP: set port 6 to learning
Sep 19 23:21:13 STP: set port 6 to forwarding
Sep 19 23:24:35 STP: set port 6 to discarding
Sep 19 23:24:35 STP: set port 6 to learning
Sep 19 23:24:35 STP: set port 6 to forwarding
Sep 19 23:40:53 switch[1364]: 24V is out of range (22.8V)
Sep 20 00:07:10 switch[1364]: 24V is out of range (22.7V)
Sep 20 00:16:00 switch[1364]: 24V is out of range (22.6V)
Sep 20 01:41:55 switch[1364]: 24V is out of range (22.7V)
Sep 20 02:46:05 switch[1364]: 24V is out of range (22.8V)
Sep 20 02:52:37 switch[1364]: 24V is out of range (22.7V)
Sep 20 03:03:17 switch[1364]: 24V is out of range (22.5V)
Sep 20 03:34:05 STP: set port 6 to discarding
Sep 20 03:34:05 STP: set port 6 to learning
Sep 20 03:34:05 STP: set port 6 to forwarding
Sep 20 03:50:38 switch[1364]: 24V is out of range (22.5V)
Sep 20 03:51:03 switch[1364]: 24V is out of range (22.6V)
Sep 20 04:21:30 switch[1364]: 24V is out of range (22.7V)
Sep 20 04:54:36 switch[1364]: 24V is out of range (22.7V)
Sep 20 04:56:36 switch[1364]: 24V is out of range (22.6V)
Sep 20 05:02:48 switch[1364]: 24V is out of range (22.7V)
Sep 20 05:18:11 switch[1364]: 24V is out of range (22.8V)
Sep 20 05:32:42 switch[1364]: 24V is out of range (22.6V)
Sep 20 05:42:26 switch[1364]: 24V is out of range (22.6V)
Sep 20 06:00:56 switch[1364]: 24V is out of range (22.7V)
Sep 20 06:41:28 STP: set port 6 to discarding
Sep 20 06:41:28 STP: set port 6 to learning
Sep 20 06:41:28 STP: set port 6 to forwarding
Sep 20 08:08:49 switch[1364]: 24V is out of range (22.7V)
Sep 20 08:15:26 switch[1364]: 24V is out of range (22.7V)
Sep 20 08:50:48 switch[1364]: 24V is out of range (22.5V)
Sep 20 09:02:39 switch[1364]: 24V is out of range (22.6V)
Sep 20 09:50:51 switch[1364]: 24V is out of range (22.5V)
Sep 20 10:02:45 switch[1364]: 24V is out of range (22.7V)
Sep 20 10:02:56 switch[1364]: 24V is out of range (22.8V)
Sep 20 10:18:14 switch[1364]: 24V is out of range (22.8V)
Sep 20 10:34:22 switch[1364]: 24V is out of range (22.7V)
Sep 20 10:50:15 switch[1364]: 24V is out of range (22.6V)
Sep 20 11:07:07 switch[1364]: 24V is out of range (22.6V)
Sep 20 11:09:02 switch[1364]: 24V is out of range (22.6V)
Sep 20 11:31:09 switch[1364]: 24V is out of range (22.6V)
Sep 20 11:45:07 STP: set port 6 to discarding
Sep 20 11:45:07 STP: set port 6 to learning
Sep 20 11:45:07 STP: set port 6 to forwarding
Wed Sep 20, 2017 1:41 pm
This unit also appears to have the defective 3.3V CAP which affects the 24V readings, or it is damaged.
Either way you need to swap this unit with the one we repaired and sent back to you and RMA this unit.
Lets get the 24V error out of the way then look at your link drops.
