I have upgraded to the latest version
i am trying to configure 3 ports with the same S-VLAN but different C-VLAN but it keeps indicating that ID should be different. iam trying to add same svlan to port 4 on the attachment
SVLAN CONFIGURATION
- ronojak
Re: SVLAN CONFIGURATION
Please post up a screen grab of the VLAN Tab of what you want to achieve along with a description of the desired effect
Also post up a screen grab of your Device/Status Tab
Look at my post footer for instructions
You can't.
You can add a S-VLAN (Q option for TPI 88a8 or D option for TPI 8100)
or
had a C-VLAN with T option. You can't do both.
Q and D are designed for use as LAN extension between customer sites.
or
