WS-12-250-AC switch: STP: MSTI0
maxbb
Tue Aug 15, 2017 10:14 am
Anyone ever seen this on a Netonix WS-12-250-AC switch:
STP: MSTI0: New root on port 4, root path cost is 240000, it's connected to M5 rocket ptp link that's connected to 5 port toughswitch for a small pop?
The major problem is that port 11 is our backhaul to the tower port 4 feeds another small pop. Any help would be appreciated.
here are some of the logs......
Jan 16 22:51:43 STP: MSTI0: New root on port 4, root path cost is 240000
Jan 16 23:05:23 STP: MSTI0: New root on port 4, root path cost is 240000
Jan 16 23:05:46 STP: MSTI0: New root on port 4, root path cost is 240000
Jan 16 23:08:43 STP: MSTI0: New root on port 4, root path cost is 240000
Jan 16 23:11:01 STP: MSTI0: New root on port 4, root path cost is 240000
Jan 16 23:15:26 STP: MSTI0: New root on port 4, root path cost is 240000
Jan 16 23:16:03 STP: MSTI0: New root on port 4, root path cost is 240000
Jan 16 23:22:06 Port: link state changed to 'down' on port 4
Jan 16 23:22:06 STP: set port 4 to discarding
Jan 16 23:22:06 Port: link state changed to 'down' on port 9
Jan 16 23:22:06 STP: set port 9 to discarding
Jan 16 23:22:06 Port: link state changed to 'down' on port 11
Jan 16 23:22:06 STP: set port 11 to discarding
Jan 16 23:22:06 Port: link state changed to 'down' on port 7
Jan 16 23:22:06 STP: set port 7 to discarding
Jan 16 23:22:07 Port: link state changed to 'up' (10M-F) on port 4
Jan 16 23:22:07 STP: set port 4 to discarding
Jan 16 23:22:07 switch[2053]: unexpected link change on port 4 (15.5/Jeff-Helm) from 100M-F to 10M-F
Jan 16 23:22:08 Port: link state changed to 'up' (100M-F) on port 7
Jan 16 23:22:08 STP: set port 7 to discarding
Jan 16 23:22:08 Port: link state changed to 'up' (100M-F) on port 9
Jan 16 23:22:08 STP: set port 9 to discarding
Jan 16 23:22:08 switch[2055]: unexpected link change on port 7 (2.4/4.10) from 1G to 100M-F
Jan 16 23:22:09 switch[2057]: unexpected link change on port 9 (2.4/4.12) from 1G to 100M-F
Jan 16 23:22:10 STP: set port 4 to learning
Jan 16 23:22:10 STP: set port 4 to forwarding
Jan 16 23:22:11 STP: set port 9 to learning
Jan 16 23:22:11 STP: set port 9 to forwarding
Jan 16 23:22:11 STP: set port 7 to learning
Jan 16 23:22:11 STP: set port 7 to forwarding
Jan 16 23:22:27 Port: link state changed to 'down' on port 9
Jan 16 23:22:27 STP: set port 9 to discarding
Jan 16 23:22:27 Port: link state changed to 'down' on port 7
Jan 16 23:22:27 STP: set port 7 to discarding
Jan 16 23:22:30 Port: link state changed to 'up' (1G) on port 7
Jan 16 23:22:30 STP: set port 7 to discarding
Jan 16 23:22:30 Port: link state changed to 'up' (1G) on port 9
Jan 16 23:22:30 STP: set port 9 to discarding
Jan 16 23:22:33 STP: set port 9 to learning
Jan 16 23:22:33 STP: set port 9 to forwarding
Jan 16 23:22:33 STP: set port 7 to learning
Jan 16 23:22:33 STP: set port 7 to forwarding
Jan 16 23:22:33 Port: link state changed to 'down' on port 4
Jan 16 23:22:33 STP: set port 4 to discarding
Jan 16 23:22:35 Port: link state changed to 'up' (100M-F) on port 4
Jan 16 23:22:35 STP: set port 4 to discarding
Jan 16 23:22:38 STP: set port 4 to learning
Jan 16 23:22:38 STP: set port 4 to forwarding
Jan 16 23:24:29 Port: link state changed to 'up' (1G) on port 11
Jan 16 23:24:29 STP: set port 11 to discarding
Note: The reason I'm posting this here is due to an official response from an email that was sent to resolve an ongoing problem where I have been having loosing connection to several ports on this switch before I start swapping switch/wire/radio.
"We offer support on our forums not via PMs or Emails.
Please make a post on our forums so that Engineers, Programmers, Techs, Associates, and other users can all see it and help. You should be detailed in your post and post up screen grabs of your config Tabs. To upload pictures to your post you use the upload attachment link below the blue button.
Thanks,
Chris"
It's not what happens to you, but how you react to it that matters.
Re: WS-12-250-AC switch: STP: MSTI0
Tue Aug 15, 2017 11:32 am
That is correct, we offer support on the forums not email and PMs for the reasons mentioned above.
However I asked you also to post up screen grabs of your Config Tabs especially your STP/RSTP/MSTP Tab.
It is know that UBNT ToughSwitch has issues with RSTP, I would disable STP on the port destined to the ToughSwitch.
If you're using RSTP or MSTP (which is in development still) you would need to show the RSTP configs on all switches in the segment for any help.
maxbb
Tue Aug 15, 2017 11:56 am
[img]file:///Users/msc/Desktop/Screen%20Shot%202017-08-15%20at%2010.51.30%20AM.png[/img][img]file:///Users/msc/Desktop/Screen%20Shot%202017-08-15%20at%2010.52.29%20AM.png[/img]
Tue Aug 15, 2017 12:11 pm
I can not see your pictures
PLEASE FOLLOW INSTRUCTIONS IN MY FOOTER AND EMAIL TO UPLOAD PICTURES
maxbb
Tue Aug 15, 2017 4:15 pm
Looks like your suggestion to disable RSTP on port connected to Tough Switch helped however problem still exists here is what it will do note port 11 is main backhaul AF5X do you think it could be a over current issue because it takes out port 4,8,9 & 10. Port 3 is backup backhaul and when i just use it this log is clean.... I'm going to drive to tower and install a POE to test my theory.... please look at what happens see log:
Jan 18 21:22:00 syslogd started: BusyBox v1.19.4
Jan 18 21:22:00 UI: Log cleared by admin (XXX.XXX.XXX)
Jan 18 21:54:36 Port: link state changed to 'down' on port 4
Jan 18 21:54:36 Port: link state changed to 'down' on port 11
Jan 18 21:54:36 STP: set port 11 to discarding
Jan 18 21:54:36 Port: link state changed to 'down' on port 8
Jan 18 21:54:36 STP: set port 8 to discarding
Jan 18 21:54:36 Port: link state changed to 'down' on port 9
Jan 18 21:54:36 STP: set port 9 to discarding
Jan 18 21:54:36 Port: link state changed to 'down' on port 10
Jan 18 21:54:36 STP: set port 10 to discarding
Jan 18 21:54:37 Port: link state changed to 'up' (10M-F) on port 4
Jan 18 21:54:38 Port: link state changed to 'up' (100M-F) on port 9
Jan 18 21:54:38 STP: set port 9 to discarding
Jan 18 21:54:38 Port: link state changed to 'up' (100M-F) on port 10
Jan 18 21:54:38 STP: set port 10 to discarding
Jan 18 21:54:38 Port: link state changed to 'up' (100M-F) on port 8
Jan 18 21:54:38 STP: set port 8 to discarding
Jan 18 21:54:41 STP: set port 8 to learning
Jan 18 21:54:41 STP: set port 8 to forwarding
Jan 18 21:54:41 STP: set port 10 to learning
Jan 18 21:54:41 STP: set port 10 to forwarding
Jan 18 21:54:41 STP: set port 9 to learning
Jan 18 21:54:41 STP: set port 9 to forwarding
Jan 18 21:54:57 Port: link state changed to 'down' on port 9
Jan 18 21:54:57 STP: set port 9 to discarding
Jan 18 21:54:58 Port: link state changed to 'down' on port 10
Jan 18 21:54:58 STP: set port 10 to discarding
Jan 18 21:55:00 Port: link state changed to 'up' (1G) on port 10
Jan 18 21:55:00 STP: set port 10 to discarding
Jan 18 21:55:00 Port: link state changed to 'up' (1G) on port 9
Jan 18 21:55:00 STP: set port 9 to discarding
Jan 18 21:55:03 STP: set port 9 to learning
Jan 18 21:55:03 STP: set port 9 to forwarding
Jan 18 21:55:03 STP: set port 10 to learning
Jan 18 21:55:03 STP: set port 10 to forwarding
Jan 18 21:55:03 Port: link state changed to 'down' on port 4
Jan 18 21:55:05 Port: link state changed to 'up' (100M-F) on port 4
Jan 18 21:55:11 Port: link state changed to 'down' on port 8
Jan 18 21:55:11 STP: set port 8 to discarding
Jan 18 21:55:14 Port: link state changed to 'up' (100M-F) on port 8
Jan 18 21:55:14 STP: set port 8 to discarding
Jan 18 21:55:17 STP: set port 8 to learning
Jan 18 21:55:17 STP: set port 8 to forwarding
Jan 18 21:55:33 Port: link state changed to 'down' on port 8
Jan 18 21:55:33 STP: set port 8 to discarding
Jan 18 21:55:36 Port: link state changed to 'up' (1G) on port 8
Jan 18 21:55:36 STP: set port 8 to discarding
Jan 18 21:55:39 STP: set port 8 to learning
Jan 18 21:55:39 STP: set port 8 to forwarding
Jan 18 21:57:08 Port: link state changed to 'up' (1G) on port 11
Jan 18 21:57:08 STP: set port 11 to discarding
Jan 18 21:57:11 STP: set port 11 to learning
Jan 18 21:57:11 STP: set port 11 to forwarding
Jan 18 21:57:28 Port: link state changed to 'down' on port 11
Jan 18 21:57:28 STP: set port 11 to discarding
Jan 18 21:57:30 Port: link state changed to 'up' (1G) on port 11
Jan 18 21:57:30 STP: set port 11 to discarding
Jan 18 21:57:33 STP: set port 11 to learning
Jan 18 21:57:33 STP: set port 11 to forwarding
Jan 18 21:57:40 UI: Configuration changed by admin (XXX.XXX.XXX.XXX)
Jan 18 21:57:40 UI: Port 11 STP: changed from 'Enabled' to 'Disabled'
Jan 18 21:57:44 STP: set port 11 to discarding
Copyright 2014-2017 Netonix
Tue Aug 15, 2017 5:19 pm
Maybe upload a network diagram showing your Layer 2 Segment including switches and links on each switch port.
There a lo of post on the forum where users suggest not using RSTP on port to AP's
Here is one list of Posts from Mike99 on RSTP there are other users with differnt configurations and suggestions as to what works best for them.
search.php?keywords=rstp&terms=all&author=mike99&sc=1&sf=all&sr=posts&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
