48VH POE Extractor/Splitter
yahel
Has thanked: 22 times
Been thanked: 22 times
Sun Aug 06, 2017 5:40 am
I need to power a Netonix DC switch (WS-8-150-DC) from another Netonix.
Since this switch does not have a POE-in like the Netonix-Mini, I would need some sort of POE-extractor.
Most off the shelf extractors would not support the 48VH.
Since I don't need this port for data, can I just short pins pins 1,2,4,5(+) for the positive, and pins 3,6,7,8(-) for the negative?
Or do I have to use 4-way center-tap transformer and a diode bridge?
Anyone know of an off-the-shelf device to do this?
Thanks,
Yahel.
PS - I'm aware that 48VH would provide a maximum of 1.5A, which at 48V is 72W --- less than half of what the WS-8-150-DC can handle - but that's fine, it would only need to power 3 AirMax devices, which are well below 40W, and the switch itself.
Re: 48VH POE Extractor/Splitter
Sun Aug 06, 2017 8:47 am
I think you did not factor for inrush current which I think would be too much for the port.
yahel
Mon Aug 07, 2017 12:15 am
In-rush cause by the 2nd Netonix switching being powered by the first?
Do we know there would be an in-rush surge that is so meaningful or are we guessing?
Mon Aug 07, 2017 1:06 am
You don't have to take my word for it. Search the forum for "inrush" and you will find where Chris says to allow for 300W of inrush.
uberdome
Has thanked: 3 times
Been thanked: 11 times
Fri Sep 22, 2017 7:43 pm
I may have missed the right post, but the inrush concerns I saw were referring to AC powered units.
I had the same question as the OP, but using two separate 48VH ports to help keep current draw low (I'm only using about 35 Watts total). I've got a site that already has 2x Cat5e running up to a steeple, so I'm debating whether to use a Netonix at the base running up to a Netonix at the top, or if I need to run separate injectors / separators to get power to the top.
Omniflux
Has thanked: 5 times
Been thanked: 32 times
Sat Sep 23, 2017 10:37 pm
I realize you are probably no longer looking for this, but for anyone searching, this is what you were looking for:
Tycon Systems POE-INJ-1000-DINX
Make sure you get a power cable to go with it, either part number 5700049 or 5700035
Sat Sep 23, 2017 11:45 pm
The POE-INJ-1000-DINX has reverse polarity on one of the pairs. Power is supplied on all 8 Ethernet pins 3,6,4,5(+) and 1,2,7,8(-).
The POE-INJ-1000-DIN (without the X) is pinned the same as the VH ports. Power is supplied on all 8 Ethernet pins 1,2,4,5(+) and 3,6,7,8(-).
Omniflux
Mon Sep 25, 2017 11:16 pm
You are correct, I will have to go back and review the one I have in use to see why my use case must be different from this.
Unfortunately, the POE-INJ-1000-DIN does not appear to work as a splitter or at least is not marketed as such.
Tue Sep 26, 2017 12:44 am
Omniflux wrote:Unfortunately, the POE-INJ-1000-DIN does not appear to work as a splitter or at least is not marketed as such.
I was told by an EE who uses them that it works both ways.
uberdome
Thu Oct 19, 2017 6:27 pm
For reference for the thread, with the info from lligetfa I ended up finding what I'm looking for:
High PoE 4 Pair Injector / Splitter Item# POE-INJ-1000-WT
http://tyconsystems.com/index.php/passi ... nj-1000-wt
It has screw terminals instead of the DIN connector, it has the same pinout as Netonix 48VH and they are quite inexpensive. I'm going to pickup a few for testing.
I was going to run 2 lines up to use this to power a DC Netonix and run a LAG connection, but I decided instead to power two WS-6-MINI switches on an ERPS loop, so I won't be using these on this particular project.
