Hi
Does the software support per vlan spanning-tree?
Sean
per vlan spanning tree
- seanwg
Re: per vlan spanning tree
PVST is Cisco propritery. MSTP is the industry standard that allow a per instance (group of VLANs) spanning-tree. Unfortunatly, on Netonix, it's still a beta feature with know bugs.
- zero
I see this was posted in 2017. IS MST on Netonix switches still a beta with known bugs or it has passed the beta stage now
Still beta. You can try if it work fine for you else report bug.
