Change voltage remotely while device is plugged in?
zrob_12 - Member
I need to change voltage on a AirFiber backhaul link (remote side) from 24v to 48v. Is there any way for me to perform this remotely?
Re: Change voltage remotely while device is plugged in?
From the GUI, you need to first power it off so it drops link. The GUI will not let you select a PoE option on a port that has link.
ISTR you can do it from SSH. There was a thread on it a while back.
zrob_12 - Member
Dang, guess I will be making a trip ; )
Users browsing this forum: Google [Bot] and 70 guests
