POE --- 12 v ?
quadra
Has thanked: 3 times
POE --- 12 v ?
Fri Jun 23, 2017 6:03 am
Hello everyone
I have a camera that only works in 12V with a rj45 port for communication
The builder of this camera tells me that it is impossible to do it in POE
I would like to be able to control the power supply via the NETONIX DC switch interface
The idea is that I get 2 wires + and - but that gives me a 12V voltage
How can I do this? :screwb:
Thank you
jakematic
Has thanked: 362 times
Been thanked: 87 times
Re: POE --- 12 v ?
Fri Jun 23, 2017 8:49 am
https://find-a-poe.com/product/WS-POE-12v/
I use 5V version for Raspberry Pi.
quadra
Re: POE --- 12 v ?
Sat Jun 24, 2017 6:28 am
Merci à toi je ne savais pas que cela existait !! Mais c'est bien plus simple !!
Merci
Users browsing this forum: Google [Bot] and 69 guests
