Help; I am unable to change the default IP of .1.20 to .2.75
I updated the firmware and have tried at least 6 times having to reset the device each time.
What am I doing wrong
Thank you
IP Adress
Re: IP Adress
WHat version of firmware?
Also after you change the IP you need login with before the revert time limit expires or it reverts to previous config.
The revert timer is a safety net so if you make a change on a switch at a remote tower and lose control and fail to login within the revert time limit it reverts to old config.
viewtopic.php?f=17&t=2704&p=18833&hilit=+revert+timer+0#p18833
Re: IP Adress
Thank you
1.4.8rc5
Frustrating as the switch just arrive this evening
Yes, I became aware of the 60 second time line. I looked I the log file and it shows it changed to the new IP however I am not able to log into it. I then restore it and repeat the process again; I have repeated the process at least 6 times.
1.4.8rc5
- Julian
Re: IP Adress
Try adding an IP address on the correct subnet to your lan adapter, say 192.168.2.255?
Re: IP Adress
I did numerous times as you described numerous times.
In any case; with the time to revert set to 300 seconds; it used to be 60 seconds prior to the firmware update Iset it to DHCP .... located it my .2.0 IP pool and will now changed it to static with the desired IP with no issues.
I appreciate your being there to assist.
Takes care.
Takes care.
Re: IP Adress
I have another quick question;
It is being powered by a Ubiquity POE injector into port 1; do I need to do any configuration on port 1or is it auto sensing with gigabit traffic supported? This the leaves the remaining 5 ports as unpowered gigabit ports until I power them as needed; correct?
Lastly; are there any setting that I should consider making to the switch before putting it into service?
Thank you again
Thank you again
Re: IP Adress
Why is the MTU unable to be adjust to 1428; 1428 is LTE MTU.
Takes care
Takes care
Re: IP Adress
Shadowman wrote:Why is the MTU unable to be adjust to 1428; 1428 is LTE MTU.
Takes care
Do not set your MTU to 1428 as this is INSANE?
Please leave your MTU at the default 1528 or you will have all kinds of problems.
The standard set by IEEE802.3 specifies the MTU of Ethernet is 1500 bytes however you want the switch set to 1528 incase you want to pass VLANs or other types of encapsulated traffic.
YOU WOULD NEVER SET YOUR MTU BELOW 1500 BUT EVEN 1500 IS TO SMALL FOR MOST BASIC NETWORKS BECAUSE OF VLANs AND OTHER TYPES OF ENCAPSULATED TRAFFIC.
