Temperature ports shutdown.
Running version 1.4.6 / F / 46/ B
For some reason i started to get ports shutdown due to overheating. We have today 89F - inside the box was about 110F
My question is what are the values at which the temps for the switch are too high and the system will start shutting down ports.
BTW the system log did not log the events. I was just watching the switch wondering what is going on and based on the priotity the switch started to turn off ports for like 25sec to about a minute.
This is my temp values. BTW I have an older unit ... AC version that is WAY hotter sits in a metal box - with board Temp close to 79C and I have absolutely no issues.
Would this revision be a special one ? BTW fan is going just fine at about 8k
Board Temp
125 C
58
-25 C
CPU Temp
125 C
80
-25 C
PHY Temp
125 C
83
-25 C
Power Supply Board Temp
125 C
52
-25 C
Power Supply Heatsink #1 Temp
125 C
48
-25 C
Power Supply Heatsink #2 Temp
125 C
48
-25 C
Power Supply Controller Temp
125 C
73
-25 C
WS-12-250-DC
kdsnetworks - Member
Re: WS-12-250-DC
Read release notes and you would see there was a fix in v1.4.8rcX for the DC switches
Please, when you have an issue read the release notes then upgrade to the LATEST version and see if the problem is still there
Re: WS-12-250-DC
I saw the dc had some issues with power but was not sure if the temps was related to it as well .. Thx will push the latest and we will see
