My setup is simple. The switch is broken up into two segments with two VLANs. All ports are set to UNTAG for their respected VLAN. Let's call the segments backbone and access.. While the backbone segment was passing traffic the access vlan was not. I even programmed some other ports and tried moving the radios to no avail.
A simple reboot restored everything to normal.
Anyone have any insight into this issue??
One VLAN locks up while the others do not..
isaacu - Member
Re: One VLAN locks up while the others do not..
Please post up screen grabs of the following TABs
Status
Ports
STP
VLANs
Device/Config
Device/Status
If the Port Description does not say what is on each port please specify what device is plugged into each port
Status
Ports
STP
VLANs
Device/Config
Device/Status
