HTTPS
quadra
Has thanked: 3 times
HTTPS
Tue Mar 21, 2017 6:31 am
Salut a tous
quand je décoche la case HTTPS dans la configuration du netonix reseau je ne peux plus me connecter au switch !!!
pourquoi ????? :headb:
Julian
Re: HTTPS
Tue Mar 21, 2017 7:26 am
Hi quadra
There is a message that pops up when you unselect the allow HTTPS checkbox; it says: " If you disable HTTPS you will not be able to access this web GUI" .. we were telling the truth..
SSH in, syntax is:
Switch> conf t
Switch(config)# https-server port 443
control-z
hit enter to confirm changes
login via web UI
