Watchdog Failure every 3 hours, then Log/Uptime Reset
jeremylu
Sun Mar 05, 2017 4:14 am
Just started happening yesterday morning at 8am, and then every 3 hours since.
Watchdog will fail, then will reboot port, when I checked the logs, it seemed they reset (Showing Dec 31, then proper date).
It has been every 3 hours for almost 24 hours straight, I'm not sure it is a problem with Netonix, just curious if this has happened to anyone else before.
Re: Watchdog Failure every 3 hours, then Log/Uptime Reset
Sun Mar 05, 2017 10:13 am
I do not follow what your describing/asking?
Start with Switch Model and firmware version.
Then explain what is going on in more detail.
I have no idea if you're saying the switch is rebooting or a watchdog rule is rebooting a device on a port?
jeremylu
Sat May 27, 2017 4:00 am
This is happening again, and seems to be unrelated to the Netonix. I'm not sure why it went away in March, but this entire setup has been acting very strangely randomly.
Ubiquiti device going offline every 3 hours, requiring AP or SM reboot. Happening for over 5 days this time, I'm now using the watchdog in the Ubiquiti device instead of netonix to attempt to pinpoint the issue. Site is also mixing airMax M and AC units over a PTMP Backhaul system (1AP, 2 sites).
Is there ANYTHING that a Netonix might do every 3 hours that could cause any strangeness? I doubt it, but just have to ask so I've explored all possibilities. This system has a Netonix switch on each side, and one is using Untagged VLAN's to separate WAN and LAN networks on a Mikrotik it is powering.
5 days of banging my head against the wall, so I'm kind of grasping at straws.
Users browsing this forum: No registered users and 76 guests
