Ws-12-250-dc SNMP and GUI freezing ?
expohl
Been thanked: 15 times
Tue Feb 21, 2017 2:44 pm
I have a DC switch that about once a month the SNMP freezes and stops feeding data to the poling server... Sometimes I can still login to the web UI and other times the login screen comes up but won't actually let me login.
I upgraded it recently from 1.3.7 to 1.4.5.rc8 thinking it would fix it but the issue persists.
Do I need to replace the switch?
Julian
Re: Ws-12-250-dc SNMP and GUI freezing ?
Tue Feb 21, 2017 2:57 pm
i would recommend upgrading to 1.4.7rc10.
1.4.5 was some months ago; can't remember if there were any specific snmp issues but I feel like i do recall something with SSL sessions not expiring properly which might cause this behavior.. Chris or Eric would know better than I, I'm a hardware guy.
cheers!
Tue Feb 21, 2017 2:58 pm
How about you upgrade to the latest firmware and see what happens
Current version is v1.4.7rc10
