I am having an issue where if I enable "Console Login" under device configuration it keeps telling me incorrect password and spitting out usage for the php command.
Am I doing something incorrectly? The console works fine before I enable authentication. It does this on my configured switch as well as another one that I have at factory defaults other than "Console Login" checked.
They are both WS-10-250-AC - here is an output from the console:
Username: admin
Password: *****
Usage: php [options] [-f] <file> [--] [args...]
php [options] -r <code> [--] [args...]
php [options] [-B <begin_code>] -R <code> [-E <end_code>] [--] [args...]
php [options] [-B <begin_code>] -F <file> [-E <end_code>] [--] [args...]
php [options] -- [args...]
php [options] -a
-a Run interactively
-c <path>|<file> Look for php.ini file in this directory
-n No php.ini file will be used
-d foo[=bar] Define INI entry foo with value 'bar'
-e Generate extended information for debugger/profiler
-f <file> Parse and execute <file>.
-h This help
-i PHP information
-l Syntax check only (lint)
-m Show compiled in modules
-r <code> Run PHP <code> without using script tags <?..?>
-B <begin_code> Run PHP <begin_code> before processing input lines
-R <code> Run PHP <code> for every input line
-F <file> Parse and execute <file> for every input line
-E <end_code> Run PHP <end_code> after processing all input lines
-H Hide any passed arguments from external tools.
-s Display colour syntax highlighted source.
-v Version number
-w Display source with stripped comments and whitespace.
-z <file> Load Zend extension <file>.
args... Arguments passed to script. Use -- args when first argument
starts with - or script is read from stdin
--ini Show configuration file names
--rf <name> Show information about function <name>.
--rc <name> Show information about class <name>.
--re <name> Show information about extension <name>.
--ri <name> Show configuration for extension <name>.
Invalid username or password
Username:
Unable To Authenticate To Console
Re: Unable To Authenticate To Console
And what version of firmware are you running?
Tried both right now, latest release and latest RC.
1.4.6
1.4.7rc6
1.4.6
1.4.7rc6
Eric Stern - Employee
- Been thanked: 130 times
This will be fixed in the next release.
