Attempted an upgrade to 1.4.6. Upgrade never completed and after 15-20 minutes, unit was unresponsive via SSH and Web.
Attempted a serial console connection to do a recovery and it returns and stops:
Init device with JEDEC ID 0x202018.
Luton26 board detected (VSC7427 Rev. D).
== Executing boot script in 5.000 seconds - enter ^C to abort
RedBoot> fis load -d linux_recovery
Image loaded from 0x80100000-0x8035016c
RedBoot> go
Linux version 2.6.26.8 (dev@netonixdev) (gcc version 4.1.2) #6 Wed Sep 17 23:49:40 EDT 201 4
Determined physical RAM map:
Zone PFN ranges:
Normal 0 -> 32768
0: 0 -> 32768
Writing ErrCtl register=80011000
Readback ErrCtl register=80011000
Memory: 126308k/131072k available (1854k kernel code, 4644k reserved, 404k data, 112k init , 0k highmem)
net_namespace: 324 bytes
TCP reno registered
JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
msgmni has been set to 246
io scheduler noop registered
console [ttyS0] enabled
No NAND device found!!!
mtd: partition "rootfs_recovery" set to be root filesystem
TCP cubic registered
Freeing unused kernel memory: 112k freed
- preinit -
Press CTRL-C for failsafe
mounting jffs2
switching to jffs2
- init -
Please press Enter to activate this console. vtss_core: module license '(c) Vitesse Semico nductor Inc.' taints kernel.
i2c /dev entries driver
mini_fo_lookup: ERROR, meta data corruption detected.
mini_fo_d_delete: negative dentry passed.
mini_fo_d_release: no private data.
RMA?
WS-24-400A Unresponsive
- Julian
Re: WS-24-400A Unresponsive
Unfortunately. Looks like something got boogered during the upgrade, the only way to fix that is JTAG.
Need a link for the RMA process thread?
- bgoode
After 6-7 tries using a variety of serial cables/WIndows versions/terminal pgms/CTL-C timing combinations, I finally was able to get a RedBoot> prompt and was able to successfully recover the switch.
Thanks....
Thanks....
- Julian
You had way better luck than I, but it's pretty easy for me to just reprogram flash, so I haven't messed with redboot much.
Glad it's working!
Glad it's working!
