Hello,
on the WS-6MINI, powered from barrell connector, after some days, we see a fluctuating voltage on the boards 48V 24V 3V with some errors in the log, as you can see below; we have changed the first swicth with a new one, thinking that could be a defective unit but after some other days, we see the same strange behavior on the new switch.
LOG:
Jan 19 07:32:23 STP: set port 4 to forwarding
Jan 21 21:28:05 switch[743]: 24V is out of range (22.5V)
Jan 22 04:13:52 switch[743]: 3V is out of range (3.1V)
Can you tell us how can we solve the issue ?
Thank you in advance.
WS-6-MINI Board48/24/3V Fluctuating voltage
- f.cucci@el-com.it
Re: WS-6-MINI Board48/24/3V Fluctuating voltage
Upgrade to v1.4.6 or preferably v1.4.7rc4
if the problem still persists then these must have defective CAPs, if so please RMA them and we will fix this ASAP and send back to you.
