FAULT on SFP 1, resetting...
AlexC
Has thanked: 8 times
Mon Jan 16, 2017 12:49 pm
I have a WS-12-250-DC running 1.4.6 whose logfile constantly fills up with this:
Jan 16 08:43:15 SFP: FAULT on SFP 1, resetting...
Jan 16 08:43:17 SFP: FAULT on SFP 1, resetting...
Jan 16 08:43:24 SFP: FAULT on SFP 1, resetting...
Jan 16 08:43:25 SFP: FAULT on SFP 1, resetting...
Jan 16 08:43:26 SFP: FAULT on SFP 1, resetting...
Jan 16 08:43:34 SFP: FAULT on SFP 1, resetting...
However there is no SFP in that switch and never has been.
Is there any way of suppressing this log entry?
Re: FAULT on SFP 1, resetting...
Mon Jan 16, 2017 1:02 pm
I would be more concerned why you are getting this message, the unit may be damaged if there is no SFP module in that port or possibly some insects have made a nest in that slot and are causing issues????
AlexC
Mon Jan 16, 2017 6:12 pm
sirhc wrote:I would be more concerned why you are getting this message, the unit may be damaged if there is no SFP module in that port or possibly some insects have made a nest in that slot and are causing issues????
I was assuming it was something software/firmware related as the message seems to indicate it already thought it had a functional SFP in the slot somehow.
I can take a look at the slot the next time i'm near that switch though. (The switch is fully functional otherwise).
Mon Jan 16, 2017 6:23 pm
Well yea the message is being generated by the software but the software seems to think there is an SFP inserted into the slot, the question is why?
Possible causes:
1) There really is a module in the slot and it was forgotten about.
2) The board is damaged or failed in some way or another.
3) Critters have made a nest in the SFP slot and somehow made an electrical connection.
AlexC
Wed Jan 18, 2017 6:28 pm
sirhc wrote:Well yea the message is being generated by the software but the software seems to think there is an SFP inserted into the slot, the question is why?
Possible causes:
I think I can rule out #1 & #3:
So maybe it has failed in some way, odd as the device is fully functional otherwise - maybe I should throw in a couple of SFPs into those ports and see if those ports do work.
(not I have tried disabling the ports fully in the configuration but its still logging these errors).
Wed Jan 18, 2017 6:32 pm
Things to try:
Power cycle
Insert a module - BUT if it is "damage" has occurred and not a faulty part UNKNOWN things could happen!!!
RMA
AlexC
Mon Jan 23, 2017 6:30 pm
Interesting installing an SFP in the port seems to have shut it up:
Jan 23 13:22:05 SFP: FAULT on SFP 1, resetting...
Jan 23 13:22:06 SFP: FAULT on SFP 1, resetting...
Jan 23 13:22:10 SFP: I2C communications up to SFP 1
Mon Jan 23, 2017 7:16 pm
Does the SFP work?
What happens if you remove SFP?
Did you try a power cycle?
AlexC
Mon Feb 20, 2017 1:23 pm
Just a quick followup.
The SFPs work afaik, but I can't check if they pas traffic as there is nothing else in the area other than the switch itself to plug it into and I wasn't to avoid creating a loop.
I haven't fully power cycled the switch, I'm unlikely to do that for a few months while its all working ok.
