Switch doesn't boot anymore
QuebecInternet
Fri Jan 06, 2017 10:47 am
we are currently having a problem with a switch that doesn't boot. Here's the output of the console :
Dec 31 19:00:04 kernel: mtd: partition "rootfs" set to be root filesystem
Dec 31 19:00:04 kernel: 0x00b00000-0x00f40000 : "rootfs_data"
Dec 31 19:00:04 kernel: 0x00f40000-0x00f80000 : "FIS directory"
Dec 31 19:00:04 kernel: 0x00f80000-0x00f81000 : "RedBoot config"
Dec 31 19:00:04 kernel: 0x00fc0000-0x01000000 : "Redundant FIS"
Dec 31 19:00:04 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Dec 31 19:00:04 kernel: TCP Dec 31 19:00:04 Dec 31 19:00:04 Dec 31 19:00:04 vtss_core: module license '(c) Vitesse Semiconductor Inc.' taints kernel.
i2c /dev entries driver
vtss_cmn_qce_del:893 qce_id: 1 not found
*** it stop here.
I tried to reset to factory default without success,
There was an electrical problem at the place where this switch was installed. Does it need to be repaired ?
Thank you
Re: Switch doesn't boot anymore
Fri Jan 06, 2017 10:53 am
You can try this: viewtopic.php?f=17&t=1073
But if that does not work you need to RMA it for repair.
RMA instructions are located here: viewtopic.php?f=6&t=1259
QuebecInternet
Fri Jan 06, 2017 12:26 pm
I don't know why but the switch suddenly start working.
Thank you for this quick answer.
Fri Jan 06, 2017 12:32 pm
QuebecInternet wrote:I don't know why but the switch suddenly start working.
What model is this?
