Power Supply Board Temp is showing 4194294 on a WS-12-250DC, my other one at the same exact site is fine.
Thought it was firmware related, had 1.4.2, upgraded to 1.4.6 still there
I was also getting text when I accessed the web gui instead of the web interface, a reload of the web would fix it, seems better after upgrade to 1.4.6.
- jeremylu
Re: Power Supply Board Temp is showing 4194294
OK so are you still get temp error?
Can you try a power cycle.
If that does not work a factory default then manually set back up.
If that does not work you need to RMA it.
- jeremylu
Ok, I will have to try it. Firmware update did nothing, so I have a feeling power cycle might not do the trick.
well if not then you're down to RMA
Users browsing this forum: Baidu [Spider] and 81 guests
