Hope someone can help..... I need to try to display the duplex status of netonix switches on our solarwinds monitoring software, have spoken to solarwinds support who think that the oid does not exist.
Does anyone have the oid for duplex status?
OID for duplex status
Re: OID for duplex status
What version of firmware are you running?
If not v1.4.6 please upgrade to that version.
The programmer (Eric) will need to assist you further but he is not online yet today, maybe it is a holiday in Canada?
Eric Stern - Employee
- Been thanked: 130 times
If you can specify which OID is required I can look into adding it in a future version.
This was solarwinds reply:
"We use this oid for the duplex status of interfaces:- 1.3.6.1.4.1.9.5.1.4.1.1.10
http://cric.grenoble.cnrs.fr/Administrateurs/Outils/MIBS/?oid=1.3.6.1.4.1.9.5.1.4.1.1.1
This OID is not supported on the device that you sent through so NPM will not be able to display the duplex state of the interfaces."
Users browsing this forum: Baidu [Spider] and 88 guests
