Hello, we have a problem with a switch that goes down for around 20 minutes and then everything come back. We had this problem on the field and this morning, I had the switch in my lab and I did got the same problem. The problem appear after being up for around 20 minutes. Here's the console output :
Dec 31 19:21:15 system: starting ntpclient
+M25PXX : Init device with JEDEC ID 0x202018.
Luton26 board detected (VSC7425 Rev. D).
== Executing boot script in 1.000 seconds - enter ^C to abort
RedBoot> fis load -d linux
Image loaded from 0x80100000-0x8036422c
RedBoot> go
Linux version 2.6.26.8 (dev@netonixdev) (gcc version 4.1.2) #2 Sun Sep 4 20:55:16 EDT 2016
Determined physical RAM map:
Zone PFN ranges:
Normal 0 -> 32768
0: 0 -> 32768
Writing ErrCtl register=8000d810
Readback ErrCtl register=8000d810
Memory: 126052k/131072k available (1917k kernel code, 4840k reserved, 417k data, 116k init, 0k highmem)
net_namespace: 640 bytes
TCP reno registered
JFFS2 version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat, Inc.
msgmni has been set to 246
io scheduler noop registered
console [ttyS0] enabled
No NAND device found!!!
mtd: partition "rootfs" set to be root filesystem
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
lo: Disabled Privacy Extensions
ip6_tables: (C) 2000-2006 Netfilter Core Team
Freeing unused kernel memory: 116k freed
- preinit -
Press CTRL-C for failsafe
mounting jffs2
switching to jffs2
- init -
Please press Enter to activate this console. Dec 31 19:00:04 syslogd started: BusyBox v1.19.4
Dec 31 19:00:04 kernel: klogd started: BusyBox v1.19.4 (2016-10-03 19:26:31 EDT)
Dec 31 19:00:04 kernel: Linux version 2.6.26.8 (dev@netonixdev) (gcc version 4.1.2) #2 Sun Sep 4 20:55:16 EDT 2016
Dec 31 19:00:04 kernel: Invalid kernel arglist - use RedBoot "exec" command to boot kernel.
Dec 31 19:00:04 kernel: Using predefined kernel options.
Dec 31 19:00:04 kernel: CPU revision is: 02019654 (MIPS 24K)
Dec 31 19:00:04 kernel: Determined physical RAM map:
Dec 31 19:00:04 kernel: User-defined physical RAM map:
Dec 31 19:00:04 kernel: memory: 08000000 @ 00000000 (usable)
Dec 31 19:00:04 kernel: Entering add_active_range(0, 0, 32768) 0 entries of 256 used
Dec 31 19:00:04 kernel: Zone PFN ranges:
Dec 31 19:00:04 kernel: Normal 0 -> 32768
Dec 31 19:00:04 kernel: Movable zone start PFN for each node
Dec 31 19:00:04 kernel: early_node_map[1] active PFN ranges
Dec 31 19:00:04 kernel: 0: 0 -> 32768
Dec 31 19:00:04 kernel: On node 0 totalpages: 32768
Dec 31 19:00:04 kernel: Normal zone: 256 pages used for memmap
Dec 31 19:00:04 kernel: Normal zone: 0 pages reserved
Dec 31 19:00:04 kernel: Normal zone: 32512 pages, LIFO batch:7
Dec 31 19:00:04 kernel: Movable zone: 0 pages used for memmap
Dec 31 19:00:04 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Dec 31 19:00:04 kernel: Kernel command line: console=ttyS0,115200 init=/etc/preinit mem=128M
Dec 31 19:00:04 kernel: Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
Dec 31 19:00:04 kernel: Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Dec 31 19:00:04 kernel: Writing ErrCtl register=8000d810
Dec 31 19:00:04 kernel: Readback ErrCtl register=8000d810
Dec 31 19:00:04 kernel: Cache parity protection enabled
Dec 31 19:00:04 kernel: PID hash table entries: 512 (order: 9, 2048 bytes)
Dec 31 19:00:04 kernel: Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Dec 31 19:00:04 kernel: Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Dec 31 19:00:04 kernel: Memory: 126052k/131072k available (1917k kernel code, 4840k reserved, 417k data, 116k init, 0k highmem)
Dec 31 19:00:04 kernel: SLUB: Genslabs=6, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Dec 31 19:00:04 kernel: Calibrating delay loop... 277.70 BogoMIPS (lpj=1388544)
Dec 31 19:00:04 kernel: Mount-cache hash table entries: 512
Dec 31 19:00:04 kernel: net_namespace: 640 bytes
Dec 31 19:00:04 kernel: NET: Registered protocol family 16
Dec 31 19:00:04 kernel: NET: Registered protocol family 2
Dec 31 19:00:04 kernel: Switched to high resolution mode on CPU 0
Dec 31 19:00:04 kernel: IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Dec 31 19:00:04 kernel: TCP established hash table entries: 4096 (order: 3, 32768 bytes)
Dec 31 19:00:04 kernel: TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
Dec 31 19:00:04 kernel: TCP: Hash tables configured (established 4096 bind 4096)
Dec 31 19:00:04 kernel: TCP reno registered
Dec 31 19:00:04 kernel: squashfs: version 3.0 (2006/03/15) Phillip Lougher
Dec 31 19:00:04 kernel: Registering mini_fo version $Id$
Dec 31 19:00:04 kernel: JFFS2 version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat, Inc.
Dec 31 19:00:04 kernel: msgmni has been set to 246
Dec 31 19:00:04 kernel: io scheduler noop registered
Dec 31 19:00:04 kernel: io scheduler deadline registered (default)
Dec 31 19:00:04 kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ sharing disabled
Dec 31 19:00:04 kernel: serial8250.0: ttyS0 at MMIO 0x70100000 (irq = 14) is a 16550A
Dec 31 19:00:04 kernel: console [ttyS0] enabled
Dec 31 19:00:04 kernel: No NAND device found!!!
Dec 31 19:00:04 kernel: m25p80 spi0.0: m25p128 (16384 Kbytes)
Dec 31 19:00:04 kernel: Mapped SPI read area @0x40000000 len 16777216
Dec 31 19:00:04 kernel: Creating 10 MTD partitions on "m25p80":
Dec 31 19:00:04 kernel: 0x00000000-0x00040000 : "RedBoot"
Dec 31 19:00:04 kernel: 0x00040000-0x00080000 : "config"
Dec 31 19:00:04 kernel: 0x00080000-0x001c0000 : "linux_recovery"
Dec 31 19:00:04 kernel: 0x001c0000-0x003c0000 : "rootfs_recovery"
Dec 31 19:00:04 kernel: 0x003c0000-0x00500000 : "linux"
Dec 31 19:00:04 kernel: 0x00500000-0x00b00000 : "rootfs"
Dec 31 19:00:04 kernel: mtd: partition "rootfs" set to be root filesystem
Dec 31 19:00:04 kernel: 0x00b00000-0x00f40000 : "rootfs_data"
Dec 31 19:00:04 kernel: 0x00f40000-0x00f80000 : "FIS directory"
Dec 31 19:00:04 kernel: 0x00f80000-0x00f81000 : "RedBoot config"
Dec 31 19:00:04 kernel: 0x00fc0000-0x01000000 : "Redundant FIS"
Dec 31 19:00:04 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Dec 31 19:00:04 kernel: TCP cubic registeredDec 31 19:00:04 vtss_core: module license '(c) Vitesse Semiconductor Inc.' taints kernel.
i2c /dev entries driver
vtss_cmn_qce_del:893 qce_id: 1 not found
Luton26 board detected�+M25PXX : Init device with JEDEC ID 0x202018.
Non-certified release, version 1_�+M25PXX : Init device with JEDEC ID 0x202018.
Non�+M25PXX : Init device with JEDEC ID 0x202018.
Non-certified release, version 1_18-Vitesse - built 05:56:+M25PXX : Init device with JEDEC ID 0x202018.
Copyrig�+M25PXX : Init device with JEDEC ID 0x202018.
Non-certified release, version 1_18-Vitesse - built 05:56:33, Jan�+M25PXX : Init device with JEDEC ID 0x202018.
Copyright (C) 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2+M25PXX : Init device with JEDEC ID 0x202018.
Copyright (C) 2000, 2001, 2002, 2003, 2004, 2005, 200�+M25PXX : Init device with JEDEC ID 0x202018.
Copyright (C) 2000, 2001, 2002, 2003, 2004, �+M25PXX : Init device with JEDEC ID 0x202018.
Free Software Foun�+M25PXX : Init device with JEDEC ID 0x202018.
Re�+M25PXX : Init device with JEDEC ID 0x202018.
Copyright (C) 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 200�+M25PXX : Init device with JEDEC ID 0x202018.
RedBoot is free sof�+M25PXX : Init device with JEDEC ID 0x202018.
RedBoot+M25PXX : Init device with JEDEC ID 0x202018.
RedBoot is free software+M25PXX : Init device with JEDEC ID 0x202018.
GNU Ge�+M25PXX : Init device with JEDEC ID 0x202018.
and so on... Until it reboot and stay up.
Is there anything to do or it's a RMA case ?
Thank you
Reboot problem with a WS-12-250AC
- QuebecInternet
- QuebecInternet
Re: Reboot problem with a WS-12-250AC
This switch has been on the field for around 6 hours before this problem started.
It was a brand new one.
- QuebecInternet
I did more test in the lab and the switch never came back after it started to reset. If I remove the power for 10 seconds, the switch start it boot process and in the middle, it start to reset. If I let it cool down, it take more time before it start resetting.
The temperature here in the field are around 4 Celsius.
It's definitively a hardware problem. I will ask for RMA
- QuebecInternet
I just pull out a WS-12-250AC from the box this morning and I configured the basic to have it accessible. One radio powered (Nanostation 5M) and one cable for management. After 2h30 runtime, the switch rebooted by itself. Again, after 2 minutes (just the time to have access to the web interface), the radio rebooted again. 5 minutes later, rebooted again. For both switch, the firmware is 1.4.5.
Here's the console output (pretty the same as I had with the same switch.
show status give :
System
Current Time: 12/31/1969 19:07:28
Uptime: 448.779999 seconds
CPU Usage: 26%
Memory Usage: 40.95 MB
MAC Address: ec:13:b2:61:ce:8e
IP Address: 10.11.156.56
IPv6 Address: fe80::ee13:b2ff:fe61:ce8e
Firmware Version: 1.4.5
Model: WS-12-250-AC
Board Rev: F
Power
Board 48V: 49.8 V
Board 24V: 24.7 V
Board 3V: 3.3 V
Thermal
Board Temp: 37 C
CPU Temp: 55 C
PHY Temp: 55 C
Cooling
Fan 1 Speed: 0 RPM
This is the reboot.
Switch Netonix 12 port# +M25PXX : Init device with JEDEC ID 0x202018.
source code and full license terms must have been made available to you�+M25PXX : Init device with JEDEC ID 0x202018.
RedBoot> go
Zone PFN ranges:
Normal 0 -> 32768
0: 0 -> 32768
Writing ErrCtl register=80049498
Readback ErrCtl register=80049498
TCP reno registered
- preinit -
mounting jffs2
switching to jffs2
- init -
show status give :
System
CPU Usage: 26%
Model: WS-12-250-AC
Board Rev: F
Power
Board 48V: 49.8 V
Board 24V: 24.7 V
Board 3V: 3.3 V
Thermal
Board Temp: 37 C
CPU Temp: 55 C
PHY Temp: 55 C
Cooling
Fan 1 Speed: 0 RPM
This is the reboot.
RedBoot> go
Zone PFN ranges:
Normal 0 -> 32768
0: 0 -> 32768
TCP reno registered
- preinit -
mounting jffs2
switching to jffs2
- init -
- QuebecInternet
2 switch out of 2 with the same problem is a little odd.
I did try to reset to factory default using the little push button and the switch booted ok (without any POE activated). I suspected a PoE problem so I tried to downgrade the firmware to a release I know it work with our 8 ports but unfortunately, the switch rebooted in the middle of the upgrade process and it's now corrupted.
- QuebecInternet
Strangely, when doing the console recovery procedure, the fan was turning full speed and the switch didn't rebooted at all...
QuebecInternet wrote:Strangely, when doing the console recovery procedure, the fan was turning full speed and the switch didn't rebooted at all...
The fan will always be at full speed until the firmware loads as the firmware controls the fan and by default the fan is on full speed.
We have seen a few defective 250 watts power supplies (I think we are up to 10+/- so far) that after a period of time reboot.
They may run fine for several hours or even as much as 12 hours then they start rebooting at random intervals. Turning them off for awhile they seem to work fine again and then after some period of time (several hours) they will start rebooting again.
This is why we are not catching them when we test them as we do not let every switch run for 12 hours, simply not possible to test for this type of issue.
Please RMA them and make sure you say on the description they reboot after a period of time, suspected power supply issue.
- QuebecInternet
Thank you.
Could it be a production lot that is in problem ? Because we bought 2 of them and both have the problem
QuebecInternet wrote:Thank you.
Well so far only found 10+/- defective powers supplies have been found out of a 2,000 batch
I am sure there are more out there yet to be found
- QuebecInternet
Ok. So we will have to setup a test bench on our side to test for this because we had to drive 4 hours and climb a mountain to change the switch. If you can test this on your side, it will be part of having a better product that we can rely on.
