Read Only Login
bflikkema
Read Only Login
Thu Nov 10, 2016 11:30 am
I'm guessing it's not possible to do this, so maybe this is a firmware request more than an issue.
I really need a read-only login versus a read-write login. That would be a minimum request. Would I would really like is multiple logins, that have varying levels of privileges. One privilege to bounce an Ethernet port, another privilege level to allow power cycling a port. I'd also say a privilege level that allows VLAN modifications, and one that allows configuration level.
jjonsson
Has thanked: 37 times
Been thanked: 65 times
Re: Read Only Login
Sun Nov 20, 2016 10:31 am
:agree:
Re: Read Only Login
Sun Nov 20, 2016 11:42 am
I had a coworker on a former job that had absolutely no fear of consequences so I have empathy for the OP's need. Some folks would probably say the solution is easy, just don't hire someone you don't trust.
netvisionip
Re: Read Only Login
Mon Jul 23, 2018 5:21 pm
I could do with a read only login, is there any further updates for this request?
