Hi all,
to start with i was running v1.4.2 on my WS-12-250-DC so tried to upgrade to 1.4.4 something went wrong lost power so had to do a firmware recovery to 1.4.4 after that i can get the login page up but after login nothing displays in all web browsers :( so did the recovery again for 1.4.5rc4 same thing tried rebooting etc still only get the login screen what am i doing wrong if anyone could please help out would be great.
admin@Netonix_Switch:/# cd /tmp
admin@Netonix_Switch:/tmp# rx recovery.tar.gz
CCCCCadmin@Netonix_Switch:/tmp#
admin@Netonix_Switch:/tmp# tar -xzf recovery.tar.gz
admin@Netonix_Switch:/tmp# rx wispswitch-1.4.5rc4.bin
CCadmin@Netonix_Switch:/tmp# tar -xjf wispswitch-1.4.5rc4.bin
te kernel.img linux
./mtd -q write fisdir "FIS directory"
./mtd -q write redundant_fisdir "Redundant FIS"
./mtd -p write rootfs.img rootfs
./mtd -q write redboot_config "RedBoot config"
reboot admin@Netonix_Switch:/tmp# ./mtd -p -F linux write kernel.img linux
Unlocking linux ...
Writing from kernel.img to linux ...
23%
46%
69%
93%
100%
Updating FIS entry linux
admin@Netonix_Switch:/tmp# ./mtd -q write fisdir "FIS directory"
Unlocking FIS directory ...
Writing from fisdir to FIS directory ...
admin@Netonix_Switch:/tmp# ./mtd -q write redundant_fisdir "Redundant FIS"
Unlocking Redundant FIS ...
Writing from redundant_fisdir to Redundant FIS ...
admin@Netonix_Switch:/tmp# ./mtd -p write rootfs.img rootfs
Unlocking rootfs ...
Writing from rootfs.img to rootfs ...
4%
8%
13%
17%
21%
26%
30%
35%
39%
43%
48%
52%
57%
61%
65%
70%
74%
79%
83%
87%
92%
96%
100%
admin@Netonix_Switch:/tmp# ./mtd -q write redboot_config "RedBoot config"
Unlocking RedBoot config ...
Writing from redboot_config to RedBoot config ...
admin@Netonix_Switch:/tmp# reboot
mini_fo_lookup: ERROR, meta data corruption detected.
mini_fo_d_delete: negative dentry passed.
mini_fo_d_release: no private data.
admin@Netonix_Switch:/tmp# Restarting system.
+M25PXX : Init device with JEDEC ID 0x202018.
Luton26 board detected (VSC7425 Rev. D).
== Executing boot script in 1.000 seconds - enter ^C to abort
RedBoot> fis load -d linux
Image loaded from 0x80100000-0x8036422c
RedBoot> go
Linux version 2.6.26.8 (dev@netonixdev) (gcc version 4.1.2) #2 Sun Sep 4 20:55:1
6 EDT 2016
Determined physical RAM map:
Zone PFN ranges:
Normal 0 -> 32768
0: 0 -> 32768
Writing ErrCtl register=8000803f
Readback ErrCtl register=8000803f
Memory: 126052k/131072k available (1917k kernel code, 4840k reserved, 417k data,
116k init, 0k highmem)
net_namespace: 640 bytes
TCP reno registered
JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
msgmni has been set to 246
io scheduler noop registered
console [ttyS0] enabled
No NAND device found!!!
mtd: partition "rootfs" set to be root filesystem
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
lo: Disabled Privacy Extensions
ip6_tables: (C) 2000-2006 Netfilter Core Team
Freeing unused kernel memory: 116k freed
- preinit -
Press CTRL-C for failsafe
mounting jffs2
switching to jffs2
- init -
Please press Enter to activate this console. Dec 31 19:00:04 syslogd started: Bu
syBox v1.19.4
Dec 31 19:00:04 kernel: klogd started: BusyBox v1.19.4 (2016-10-03 19:26:31 EDT)
Dec 31 19:00:04 kernel: Linux version 2.6.26.8 (dev@netonixdev) (gcc version 4.1
.2) #2 Sun Sep 4 20:55:16 EDT 2016
Dec 31 19:00:04 kernel: Invalid kernel arglist - use RedBoot "exec" command to b
oot kernel.
Dec 31 19:00:04 kernel: Using predefined kernel options.
Dec 31 19:00:04 kernel: CPU revision is: 02019654 (MIPS 24K)
Dec 31 19:00:04 kernel: Determined physical RAM map:
Dec 31 19:00:04 kernel: User-defined physical RAM map:
Dec 31 19:00:04 kernel: memory: 08000000 @ 00000000 (usable)
Dec 31 19:00:04 kernel: Entering add_active_range(0, 0, 32768) 0 entries of 256
used
Dec 31 19:00:04 kernel: Zone PFN ranges:
Dec 31 19:00:04 kernel: Normal 0 -> 32768
Dec 31 19:00:04 kernel: Movable zone start PFN for each node
Dec 31 19:00:04 kernel: early_node_map[1] active PFN ranges
Dec 31 19:00:04 kernel: 0: 0 -> 32768
Dec 31 19:00:04 kernel: On node 0 totalpages: 32768
Dec 31 19:00:04 kernel: Normal zone: 256 pages used for memmap
Dec 31 19:00:04 kernel: Normal zone: 0 pages reserved
Dec 31 19:00:04 kernel: Normal zone: 32512 pages, LIFO batch:7
Dec 31 19:00:04 kernel: Movable zone: 0 pages used for memmap
Dec 31 19:00:04 kernel: Built 1 zonelists in Zone order, mobility grouping on.
Total pages: 32512
Dec 31 19:00:04 kernel: Kernel command line: console=ttyS0,115200 init=/etc/pre
init mem=128M
Dec 31 19:00:04 kernel: Primary instruction cache 32kB, VIPT, 4-way, linesize 32
bytes.
Dec 31 19:00:04 kernel: Primary data cache 32kB, 4-way, VIPT, cache aliases, lin
esize 32 bytes
Dec 31 19:00:04 kernel: Writing ErrCtl register=8000803f
Dec 31 19:00:04 kernel: Readback ErrCtl register=8000803f
Dec 31 19:00:04 kernel: Cache parity protection enabled
Dec 31 19:00:04 kernel: PID hash table entries: 512 (order: 9, 2048 bytes)
Dec 31 19:00:04 kernel: Dentry cache hash table entries: 16384 (order: 4, 65536
bytes)
Dec 31 19:00:04 kernel: Inode-cache hash table entries: 8192 (order: 3, 32768 by
tes)
Dec 31 19:00:04 kernel: Memory: 126052k/131072k available (1917k kernel code, 48
40k reserved, 417k data, 116k init, 0k highmem)
Dec 31 19:00:04 kernel: SLUB: Genslabs=6, HWalign=32, Order=0-3, MinObjects=0, C
PUs=1, Nodes=1
Dec 31 19:00:04 kernel: Calibrating delay loop... 277.70 BogoMIPS (lpj=1388544)
Dec 31 19:00:04 kernel: Mount-cache hash table entries: 512
Dec 31 19:00:04 kernel: net_namespace: 640 bytes
Dec 31 19:00:04 kernel: NET: Registered protocol family 16
Dec 31 19:00:04 kernel: NET: Registered protocol family 2
Dec 31 19:00:04 kernel: Switched to high resolution mode on CPU 0
Dec 31 19:00:04 kernel: IP route cache hash table entries: 1024 (order: 0, 4096
bytes)
Dec 31 19:00:04 kernel: TCP established hash table entries: 4096 (order: 3, 3276
8 bytes)
Dec 31 19:00:04 kernel: TCP bind hash table entries: 4096 (order: 2, 16384 bytes
Dec 31 19:00:04 kernel: TCP: Hash tables configured (established 4096 bind 4096)
Dec 31 19:00:04 kernel: TCP reno registered
Dec 31 19:00:04 kernel: squashfs: version 3.0 (2006/03/15) Phillip Lougher
Dec 31 19:00:04 kernel: Registering mini_fo version $Id$
Dec 31 19:00:04 kernel: JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Ha
t, Inc.
Dec 31 19:00:04 kernel: msgmni has been set to 246
Dec 31 19:00:04 kernel: io scheduler noop registered
Dec 31 19:00:04 kernel: io scheduler deadline registered (default)
Dec 31 19:00:04 kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ
sharing disabled
Dec 31 19:00:04 kernel: serial8250.0: ttyS0 at MMIO 0x70100000 (irq = 14) is a 1
6550A
Dec 31 19:00:04 kernel: console [ttyS0] enabled
Dec 31 19:00:04 kernel: No NAND device found!!!
Dec 31 19:00:04 kernel: m25p80 spi0.0: m25p128 (16384 Kbytes)
Dec 31 19:00:04 kernel: Mapped SPI read area @0x40000000 len 16777216
Dec 31 19:00:04 kernel: Creating 10 MTD partitions on "m25p80":
Dec 31 19:00:04 kernel: 0x00000000-0x00040000 : "RedBoot"
Dec 31 19:00:04 kernel: 0x00040000-0x00080000 : "config"
Dec 31 19:00:04 kernel: 0x00080000-0x001c0000 : "linux_recovery"
Dec 31 19:00:04 kernel: 0x001c0000-0x003c0000 : "rootfs_recovery"
Dec 31 19:00:04 kernel: 0x003c0000-0x00500000 : "linux"
Dec 31 19:00:04 kernel: 0x00500000-0x00b00000 : "rootfs"
Dec 31 19:00:04 kernel: mtd: partition "rootfs" set to be root filesystem
Dec 31 19:00:04 kernel: 0x00b00000-0x00f40000 : "rootfs_data"
Dec 31 19:00:04 kernel: 0x00f40000-0x00f80000 : "FIS directory"
Dec 31 19:00:04 kernel: 0x00f80000-0x00f81000 : "RedBoot config"
Dec 31 19:00:04 kerDec 31 19:00:04 Dec 31 19:00:04 Dec 31 19:00:04 Dec 31 19:00:
04 vtss_core: module license '(c) Vitesse Semiconductor Inc.' taints kernel.
i2c /dev entries driver
mini_fo: create_sto_file: ERROR creating sto file.
Thanks Brent
Help no web GUI after recovery
Eric Stern - Employee
- Been thanked: 130 times
Re: Help no web GUI after recovery
Try these commands at the command line:
mtd erase /dev/mtd6
reboot
The first command should take about 30 seconds. Also the reboot will take longer than usual. When its done the switch will be in a factory default state.
mtd erase /dev/mtd6
reboot
great stuff thanks lots all go now :)
Brent
Brent
isaacu - Member
Eric Stern wrote:Try these commands at the command line:
mtd erase /dev/mtd6
reboot
Having same issue. returning %invalid command for me...
