Hello,
I have strange behavior of switch (WS-8-150-DC FW 1.4.5rc4):
1. With mikrotik routers. if i connect to switch port1 with poe 24v(0,75a) mikrotik at this moment "map lite" uses 5,1W ,but if i change the port to port2 with same poe 24v(0,75a) it uses only 1,2-2w . Is it normal?
2. other thing that the switch is able to get up only with 10M-Half when that port on mikrotik map lite is 1G-Full. Way it can't get up with 1G? cable length is 10cm, and tested with 3m cable.... same staff..
3. When i use the same map lite with 48V(0,75a) and If the port is down but power is on on the port ,the status of usage wattage is not shown (0.00) auto negotiation is not working. shows port is down. (But power to the port is turned on,and map lite starts up)
I have ws-12-250-DC but not tested yet.Tomorrow i will test the same equipment. and also with other products of ubnt, mikrotik, siklu to test behavior of switches.
WS-8-150-DC
- TheNet
Re: WS-8-150-DC
TheNet wrote:Hello,
Sounds like the switch might be damaged, possibly Ethernet transformer and or current sensors?
Do a cable diagnostics on each port with no cable attached and report what you find.
You should get OPEN, OPEN, OPEN, OPEN on every port.
Next on your bench use a know good UBNT radio and turn 24V on for each port and test each port one at a time and note the watts reported and report back.
- TheNet
Re: WS-8-150-DC
Hello,
after power off device and start up in today, the switch is stuck in booting process. post the console screen.
what should i do now? reset default.. try to put firmware through console??? any ideas.. its brand new from the box device .
MFG Date: 08/10/2016 v1.4.2 RevF - (at with moment the firmware version is 1.4.5rc4)
Motherboard S/N: 147814-0982
- Code: Select all
+M25PXX : Init device with JEDEC ID 0x202018.
Luton10 board detected (VSC7424 Rev. D).
== Executing boot script in 1.000 seconds - enter ^C to abort
RedBoot> fis load -d linux
Image loaded from 0x80100000-0x8036422c
RedBoot> go
Linux version 2.6.26.8 (dev@netonixdev) (gcc version 4.1.2) #2 Sun Sep 4 20:55:16 EDT 2016
Determined physical RAM map:
Zone PFN ranges:
Normal 0 -> 32768
0: 0 -> 32768
Writing ErrCtl register=80001180
Readback ErrCtl register=80001180
Memory: 126052k/131072k available (1917k kernel code, 4840k reserved, 417k data, 116k init, 0k highmem)
net_namespace: 640 bytes
TCP reno registered
JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
msgmni has been set to 246
io scheduler noop registered
console [ttyS0] enabled
No NAND device found!!!
mtd: partition "rootfs" set to be root filesystem
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
lo: Disabled Privacy Extensions
ip6_tables: (C) 2000-2006 Netfilter Core Team
Freeing unused kernel memory: 116k freed
- preinit -
Press CTRL-C for failsafe
mounting jffs2
switching to jffs2
- init -
Please press Enter to activate this console. Jan 1 00:00:04 syslogd started: BusyBox v1.19.4
Jan 1 00:00:04 kernel: klogd started: BusyBox v1.19.4 (2016-10-03 19:26:31 EDT)
Jan 1 00:00:04 kernel: Linux version 2.6.26.8 (dev@netonixdev) (gcc version 4.1.2) #2 Sun Sep 4 20:55:16 EDT 2016
Jan 1 00:00:04 kernel: Invalid kernel arglist - use RedBoot "exec" command to boot kernel.
Jan 1 00:00:04 kernel: Using predefined kernel options.
Jan 1 00:00:04 kernel: CPU revision is: 02019654 (MIPS 24K)
Jan 1 00:00:04 kernel: Determined physical RAM map:
Jan 1 00:00:04 kernel: User-defined physical RAM map:
Jan 1 00:00:04 kernel: memory: 08000000 @ 00000000 (usable)
Jan 1 00:00:04 kernel: Entering add_active_range(0, 0, 32768) 0 entries of 256 used
Jan 1 00:00:04 kernel: Zone PFN ranges:
Jan 1 00:00:04 kernel: Normal 0 -> 32768
Jan 1 00:00:04 kernel: Movable zone start PFN for each node
Jan 1 00:00:04 kernel: early_node_map[1] active PFN ranges
Jan 1 00:00:04 kernel: 0: 0 -> 32768
Jan 1 00:00:04 kernel: On node 0 totalpages: 32768
Jan 1 00:00:04 kernel: Normal zone: 256 pages used for memmap
Jan 1 00:00:04 kernel: Normal zone: 0 pages reserved
Jan 1 00:00:04 kernel: Normal zone: 32512 pages, LIFO batch:7
Jan 1 00:00:04 kernel: Movable zone: 0 pages used for memmap
Jan 1 00:00:04 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Jan 1 00:00:04 kernel: Kernel command line: console=ttyS0,115200 init=/etc/preinit mem=128M
Jan 1 00:00:04 kernel: Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
Jan 1 00:00:04 kernel: Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Jan 1 00:00:04 kernel: Writing ErrCtl register=80001180
Jan 1 00:00:04 kernel: Readback ErrCtl register=80001180
Jan 1 00:00:04 kernel: Cache parity protection enabled
Jan 1 00:00:04 kernel: PID hash table entries: 512 (order: 9, 2048 bytes)
Jan 1 00:00:04 kernel: Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Jan 1 00:00:04 kernel: Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Jan 1 00:00:04 kernel: Memory: 126052k/131072k available (1917k kernel code, 4840k reserved, 417k data, 116k init, 0k highmem)
Jan 1 00:00:04 kernel: SLUB: Genslabs=6, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Jan 1 00:00:04 kernel: Calibrating delay loop... 277.70 BogoMIPS (lpj=1388544)
Jan 1 00:00:04 kernel: Mount-cache hash table entries: 512
Jan 1 00:00:04 kernel: net_namespace: 640 bytes
Jan 1 00:00:04 kernel: NET: Registered protocol family 16
Jan 1 00:00:04 kernel: NET: Registered protocol family 2
Jan 1 00:00:04 kernel: Switched to high resolution mode on CPU 0
Jan 1 00:00:04 kernel: IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 00:00:04 kernel: TCP established hash table entries: 4096 (order: 3, 32768 bytes)
Jan 1 00:00:04 kernel: TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
Jan 1 00:00:04 kernel: TCP: Hash tables configured (established 4096 bind 4096)
Jan 1 00:00:04 kernel: TCP reno registered
Jan 1 00:00:04 kernel: squashfs: version 3.0 (2006/03/15) Phillip Lougher
Jan 1 00:00:04 kernel: Registering mini_fo version $Id$
Jan 1 00:00:04 kernel: JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
Jan 1 00:00:04 kernel: msgmni has been set to 246
Jan 1 00:00:04 kernel: io scheduler noop registered
Jan 1 00:00:04 kernel: io scheduler deadline registered (default)
Jan 1 00:00:04 kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ sharing disabled
Jan 1 00:00:04 kernel: serial8250.0: ttyS0 at MMIO 0x70100000 (irq = 14) is a 16550A
Jan 1 00:00:04 kernel: console [ttyS0] enabled
Jan 1 00:00:04 kernel: No NAND device found!!!
Jan 1 00:00:04 kernel: m25p80 spi0.0: m25p128 (16384 Kbytes)
Jan 1 00:00:04 kernel: Mapped SPI read area @0x40000000 len 16777216
Jan 1 00:00:04 kernel: Creating 10 MTD partitions on "m25p80":
Jan 1 00:00:04 kernel: 0x00000000-0x00040000 : "RedBoot"
Jan 1 00:00:04 kernel: 0x00040000-0x00080000 : "config"
Jan 1 00:00:04 kernel: 0x00080000-0x001c0000 : "linux_recovery"
Jan 1 00:00:04 kernel: 0x001c0000-0x003c0000 : "rootfs_recovery"
Jan 1 00:00:04 kernel: 0x003c0000-0x00500000 : "linux"
Jan 1 00:00:04 kernel: 0x00500000-0x00b00000 : "rootfs"
Jan 1 00:00:04 kernel: mtd: partition "rootfs" set to be root filesystem
Jan 1 00:00:04 kernel: 0x00b00000-0x00f40000 : "rootfs_data"
Jan 1 00:00:04 kernel: 0x00f40000-0x00f80000 : "FIS directory"
Jan 1 00:00:04 kernel: 0x00f80000-0x00f81000 : "RedBoot config"
Jan 1 00:00:04 kernel: 0x00fc0000-0x01000000 : "Redundant FIS"
Jan 1 00:00:04 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
vtss_core: module license '(c) Vitesse Semiconductor Inc.' taints kernel.
i2c /dev entries driver
Re: WS-8-150-DC
Yea, try factory default, with the console cable hooked up apply power holding in the default button and you should see on the console when it registers the default button pressed then let up and wait up to 3-4 minutes as it needs to re-format the JFFS file system.
If that does not fix it you may need to RMA it?
