GUI Non Responsive
robgnet
GUI Non Responsive
Wed Sep 14, 2016 4:09 pm
Hello,
I have a WS-6-MINI, and the GUI is not responding. I had this problem on 1.4.3r and after upgrading to 1.4.4, I also have the same issue. I tried to SSH to the device but getting connection errors, even though SSH is enabled in the switch. What can I do to get into my device and or troubleshoot this issue?
Re: GUI Non Responsive
Thu Sep 15, 2016 8:59 am
What is the connection error you get when you try to ssh to the switch ?
Thu Sep 15, 2016 9:18 am
I would try factory defaulting it and setting it back up.
Hold the factory default button in for 20 seconds when apply power then let it set a few minutes as it need to re-format the JFFS2 file system.
