DC switch issues
j2sw
DC switch issues
Tue Aug 23, 2016 12:29 am
We have two major issues going on with an install.
Problem #1.
The voltage is reading 16-18 volts on the power supply. The readout on the input voltage says 24.6 volts. What would be causing the voltage loss?
Problem #2
I logged into the switch tonight and all the POE ports said errors. Now I can't get into the switch. If I disable and re-enable the SFP port on my Mikrotik at the bottom then ping to the switch start again, but only last 3-5 seconds.
Re: DC switch issues
Tue Aug 23, 2016 12:37 am
You switch is more then likely damaged, you will need to RMA it do determine if it is a failure or damage but most often this is damage from a surge or ground potential shift.
Previously discussed here and other places on the forums:
viewtopic.php?f=17&t=1871&p=13924&hilit=+current+sensor+damage#p13924
viewtopic.php?f=17&t=1867&p=13888&hilit=+current+sensor+damage#p13888
But you should first try a cold reboot / power cycle and upgrade to latest firmware which is v1.4.3.rc6
Follow the RMA instructions here: viewtopic.php?f=6&t=1259
viewtopic.php?f=30&t=1816
viewtopic.php?f=30&t=188
viewtopic.php?f=30&t=1429
