Der WS-12-250-DC gibt die "DCDC Input Voltage" über SNMP aus (OID voltage.4).
Beim WS-12-150-DC fehlt dieser Wert aber (siehe unten).
Im Webinterface auf sw1.gsb1 wird
der Wert aber unter Device->Status aber angezeigt (als Power Supply Input Voltage).
Via webinterface --> device I can see the power supply Input voltage! So it should be there! But as you can see below it is missing!
ok: everything works fine:
root@centreon:/usr/local/nagios/libexec# snmpwalk -v 2c -c public
-m+./NETONIX-SWITCH-MIB.dat 10.11.4.51 voltageTable
NETONIX-SWITCH-MIB::voltageIndex.1 = INTEGER: 1
NETONIX-SWITCH-MIB::voltageIndex.2 = INTEGER: 2
NETONIX-SWITCH-MIB::voltageIndex.3 = INTEGER: 3
NETONIX-SWITCH-MIB::voltageIndex.4 = INTEGER: 4
NETONIX-SWITCH-MIB::voltageIndex.5 = INTEGER: 5
NETONIX-SWITCH-MIB::voltageDescription.1 = STRING: Board 48V
NETONIX-SWITCH-MIB::voltageDescription.2 = STRING: Board 24V
NETONIX-SWITCH-MIB::voltageDescription.3 = STRING: Board 3V
NETONIX-SWITCH-MIB::voltageDescription.4 = STRING: DCDC Input Voltage
NETONIX-SWITCH-MIB::voltageDescription.5 = STRING: DCDC Output Voltage
NETONIX-SWITCH-MIB::voltage.1 = INTEGER: 49.20
NETONIX-SWITCH-MIB::voltage.2 = INTEGER: 24.90
NETONIX-SWITCH-MIB::voltage.3 = INTEGER: 3.30
NETONIX-SWITCH-MIB::voltage.4 = INTEGER: 27.40
NETONIX-SWITCH-MIB::voltage.5 = INTEGER: 49.90
error:
(Eintrag 4 und 5 fehlt, wir brauchen 4): (voltage.4 and voltage.5 are missing) we need voltage.4
-m+./NETONIX-SWITCH-MIB.dat 10.11.1.51 voltageTable
NETONIX-SWITCH-MIB::voltage.2 = INTEGER: 24.20
Any ideas? Thanks...
DCDC Input Voltage - WS-12-150-DC
- ystenzel
Re: DCDC Input Voltage - WS-12-150-DC
What version of firmware are you using?
Have you tried v1.4.3rc4 as there were some SNMP changes/fixes
