802.1x port control access
fredgost
Tue Aug 09, 2016 6:31 pm
We would like to control the port access of each netonix switch on our network.
Can we use a radius server with 802.1x ?
Do they support 802.1x on each port ?
Eric Stern
Been thanked: 130 times
Re: 802.1x port control access
Tue Aug 09, 2016 6:55 pm
We do not currently support 802.1x.
Tue Aug 09, 2016 7:01 pm
Are you asking for Radius authentication to log into the switch or something else as we do support Radius Authentication to login to the UI or CLI
Look on the Device Configuration Tab for Radius Authentication under credentials.
fredgost
Wed Aug 10, 2016 3:32 am
We would like to control each port (allow/not allow) and also a Radius authentication to login.
We are searching to block anyone who put a computer to discover the network and vlan (with wireshark etc.)
Can we use on the device configutration the Radius Authentication for credentials to login to the UI or CLI ?
Wed Aug 10, 2016 7:50 am
fredgost wrote:We would like to control each port (allow/not allow) and also a Radius authentication to login.
Can we use on the device configuration the Radius Authentication for credentials to login to the UI or CLI ?
We do not support radius authentication for port access but yes radius authentication to login to the UI/CLI is supported already.
fredgost
Wed Aug 10, 2016 2:01 pm
Ok.
Thank you
