Possibly a bad switch?
mayheart
Has thanked: 48 times
Been thanked: 60 times
Fri Aug 05, 2016 5:51 am
I have a switch that says Error for wattage/temperature. This was running 1.3.7, upgrading it to 1.4.3rc4 has no effect.
There's no difference with the APs unplugged or not.
Screenshots attached
Re: Possibly a bad switch?
Fri Aug 05, 2016 8:19 am
This normally happens when the switch takes damage and the current sensors are blown.
Since all the sensors use the same I2C bus if the switch took a bad enough hit it can take out the I2C bus and all the sensors report error like that.
Could be a failure or could be damaged wither way we can repair it.
If it is a failure the repair is free if it is damaged we charge a fee to replaced the board.
Here is where you get RMA instructions: viewtopic.php?f=6&t=1259
viewtopic.php?f=30&t=1816
viewtopic.php?f=30&t=188
viewtopic.php?f=30&t=1429
