v1.4.3rcX Bug Reports and Comments
Thu Jul 21, 2016 11:27 am
Please post comments and report bugs for v1.4.3rcX in this thread
THREAD CLOSED PLEASE USE v1.4.3
v1.4.3rcX wrote:FIXED
- Fixed shell exit
- Fixed missing field on scheduled port bounces created in CLI which would cause a config file to become corrupt - URGENT - rc3
- Fixed occasional invalid statistics reported to the UI - rc3
- Fixed clearing of stats on SFP ports - rc3
- Removed disabling poe if port has link while turning on power - rc3
- Changed SNMP ifName/ifDescr/ifAlias - rc3
- Fixed console login when using passwords with special characters - rc4
- Fix power budget on WS-8-150-DC - rc4
- Fix CDP and LLDP on SFP ports on 12 port models - rc4
- Fixed SMTP so it send emails in a background process, could have caused UI to become unreponsive if there was an issue with server - rc4
- Fixed reboot command to properly do warm boot - rc6
- New fix for igmp snooping on vlans - rc6
- Fixed incorrect port number on LACP notification - rc6
- Fixed colour of 100M links on SFP ports - rc6
- Fixed bug that was introduced in v1.4.3rc4 that would cause duplicate switch processes to start whenever an email alert is sent and eat up CPU time. - rc7
ENHANCEMENTS
- Reduce resource usage of ubiquiti discovery - rc3
- Increased Pause Frame Storm Threshold from 10K unsolicited Pause Frames per second for 5 seconds to 15K unsolicited Pause Frames per second for 10 seconds - rc3
- Added pause frame count logging when Pause Frame Storm Protection trips - rc3
- Add graphic to firmware update - rc3
- Added BRIDGE-MIB to SNMP - rc3
- Added port name to email - rc3
- Added configurable email alerts so you can select which messages are sent via SMTP - rc3
- Added ifType to SNMP - rc4
- Moved email alerts config to a dialog - rc4
- Unexpected link change message now indicates speed - rc4
- Added button to flush mac table - rc4
- Added America/Creston timezone - rc6
KNOWN ISSUES
- Some language templates need help - please contact us to help
rc3 - Released 7/21/2016
rc4 - Released 7/31/2016
rc5 - Released 8/10/2016
rc6 - Released 8/16/2016
rc7 - Released 8/23/2016
Re: v1.4.3rcX Bug Reports and Comments
Thu Jul 21, 2016 5:19 pm
Installed on WS-24 and WS-6 without any drama.
WisTech
Has thanked: 9 times
Been thanked: 64 times
Tue Jul 26, 2016 5:43 pm
I've had no problems with it on 12 port AC, and 6-Mini I deployed.
mayheart
Has thanked: 48 times
Been thanked: 60 times
Sun Jul 31, 2016 5:50 am
Odd message while upgrading from 1.4.0 to 1.4.3rc3. The unit rebooted fine though.
Code: Select all
 Do not turn off power while upgrade is in progress!Uploading firmware file ...Unpacking firmware ...
sh: missing ]
/usr/bin/firmware_upgrade: line 150: WS-12-250-AC: not found
Running preflash script ...
Unlocking /dev/mtd8 ...
Writing from redboot_recovery_config to /dev/mtd8 ...
Unlocking linux ...
Writing from kernel.img to linux ...
Updating FIS entry linux
Unlocking FIS directory ...
Writing from fisdir to FIS directory ...
Unlocking Redundant FIS ...
Writing from redundant_fisdir to Redundant FIS ...
Unlocking rootfs ...
Writing from rootfs.img to rootfs ...
Sun Jul 31, 2016 7:57 am
mayheart wrote:Odd message while upgrading from 1.4.0 to 1.4.3rc3. The unit rebooted fine though.
Yes, that was a bug in v1.4.0 which is one reason it was short lived, had several other bugs to.
Remember when you do an upgrade your using the old version code that is installed in this case v1.4.0 until the 1st complete reboot is done.
v1.4.3rc4 Released
Sun Jul 31, 2016 8:29 am
v1.4.3rc4 released, see release notes for changes
rste
Wed Aug 03, 2016 4:30 am
Why not use crowdin or transifex.
I used crowdin many times for other projects.
sakita
Has thanked: 110 times
Been thanked: 90 times
Thu Aug 04, 2016 10:17 am
Installed 1.4.3rc4 on WS-12-250-DC and LLDP is working fine on both copper and fiber ports.
Netonix sees neighbor switches as before and now the neighbor Ruggedcom switches are receiving LLDP packets and seeing Netonix. :hurray:
mayheart
Fri Aug 05, 2016 5:54 am
I have one switch I upgraded to 1.4.3rc4 from 1.4.2.
There's only me logged into it and this keeps popping up:
"The configuration has changed on the device. You will not be able to save any configuration changes. Click here to reload the configuration."
I've tried different browsers/clearing cache. The message always comes back.
This is the only real problem I've seen with rc4... considering we have over 100 of these in use.
mayheart
Fri Aug 05, 2016 9:18 am
Reboot of that switch is still producing the message.
Possible UI bug of somesorts?
