WS-8-150-DC SNMP
kdsnetworks
WS-8-150-DC SNMP
Sat Jul 16, 2016 1:25 am
Hi All,
Finally started to use the new smaller DC switch and we cant pull input voltage via the official MIB
The only voltage readings available are the 48 24 and 3 v
Please advise ...
R
Update : WS-12- DC works just fine and we can read all 5 voltage sensors.
Avant
Re: WS-8-150-DC SNMP
Mon Jul 25, 2016 4:58 pm
This is getting to us as well. We wanted to use the WS-8-150-DC for our remote AP's and use the Netonix as the voltage monitor for the batteries but without SNMP access or other way to plot the input voltage, no monitoring. This is also true for the Mini-6. I hope this is just an oversight...
Eric Stern
Been thanked: 130 times
Mon Jul 25, 2016 5:07 pm
WS-8-150-DC will be fixed in the next release.
Mon Jul 25, 2016 6:25 pm
Avant wrote:This is also true for the Mini-6. I hope this is just an oversight...
I don't understand? The Board 48V plus the diode drop is the same voltage as Vin on the barrel so just add .7V and that is Vin. If doing PoE in, then add 1.4V.
iso.3.6.1.4.1.46242.4.1.2.1 = STRING: "Board 48V"
iso.3.6.1.4.1.46242.4.1.2.2 = STRING: "Board 24V"
iso.3.6.1.4.1.46242.4.1.2.3 = STRING: "Board 3V"
iso.3.6.1.4.1.46242.4.1.3.1 = INTEGER: 4510
iso.3.6.1.4.1.46242.4.1.3.2 = INTEGER: 2400
iso.3.6.1.4.1.46242.4.1.3.3 = INTEGER: 330
Avant
Tue Jul 26, 2016 10:59 pm
@lligetfa.. We are talking about the 150-DC which does not have a "barrel" it takes input voltage from 9V to 72V. That is what we need via snmp...
Tue Jul 26, 2016 11:34 pm
As Eric said, he will fix it for the WS-8-150-DC in the next release. I know the WS-8 doesn't have a barrel connector. I was addressing your comment:
I don't understand what parallels you are drawing.
Avant
Wed Jul 27, 2016 5:20 pm
Ah, I didn't understand you were referencing the Mini-6 and the barrel connector. Got it, thanks!
