We've installed a few WS-8-150-DC switches. 1.4.1 & .2 just reports error in the watts column. Going to the configuration page, there is error in all the power related data fields.
Is there s solution to this?
Also are there MIBs for all the power fields for SNMP?
1.4.1/2 New 8 port DC switches - Error communicating with po
kshogan - Member
Re: 1.4.1/2 New 8 port DC switches - Error communicating wit
In logs...
ec 31 17:00:49 switch[1333]: i2c link down, in recovery mode
I would upgrade to v1.4.2 and power cycle it just in case.
but if the switch is not installed near an FM broadcast tower and you test the switch on a bench and the watts or voltage or I2C error is still present then typically the current sensors got damaged from surges or ground potential shift.
You can do an advanced search and read a lot of post discussing this
Advanced search like: +damage +current +sensors
viewtopic.php?f=17&t=1560&p=11537&hilit=+current+sensor+damage#p11537
viewtopic.php?f=17&t=1216&p=13798&hilit=+current+sensor+damage#p13798
viewtopic.php?f=17&t=1523&p=11293&hilit=+current+sensor+damage#p11293
viewtopic.php?f=30&t=1816
viewtopic.php?f=30&t=188
viewtopic.php?f=30&t=1429
To RMA your switch read this thread: viewtopic.php?f=6&t=1259
If the unit failed it is fixed for free but if it is damaged we will still fix it for a fee.
