Default Configuration Files
MichaelBrandl
Has thanked: 4 times
Mon Jul 04, 2016 10:44 am
We use a custom program to edit and create configuration files automatically before our engineers go to site, they then upload the pre-generated configuration and off they go :)
However, with each new build of software, the default configuration get's a slight tweak and to keep up to date we should really change around this program so that it still works.
So my question is, can we get a copy of the default configuration for each switch for each new version so that we can load this into our program?
Mike
jjonsson
Has thanked: 37 times
Been thanked: 65 times
Re: Default Configuration Files
Mon Jul 04, 2016 5:42 pm
What about stripping down of the config files ? Would that be possible. So that they only contain needed parts that needs to be changed ?
Or maybe a config file editor ?
