Hello Support,
I am having issues changing the IP address of a switch via the CLI. I am using putty as the terminal, when I change the IP:
Configure terminal
ip address 192.168.x.x
The commands are input and I am able to connect via another putty session for a time. The config reverts to the original settings because I was not able to confirm the configuration.
Is there a way to do this via CLI? The GUI is unresponsive on all firmware versions I have tried. (v1.4.0rc22, v1.3.9). The Minis do not have a serial port. It would be great to do as I have 30+ devices to configure.
Cheers,
RDon
WS-6-MINI IP changes via CLI | BUG
- RDon
Re: WS-6-MINI IP changes via CLI | BUG
Try using a different browser like Chrome as the UI is very responsive, has to be your browser or computer. Our UI is VERY responsive.
If you go under the Device/Configuration Tab in the UI you can disable the Revert Timer by setting it to "0" then it will never revert config even if you screw up.
- RDon
Yes Chrome works 100x faster thank you.
Also the revert timer will be useful.
Cheers,
Cheers,
