Switch Name in From Header of Messages
tma
Has thanked: 15 times
Been thanked: 14 times
Tue Apr 19, 2016 5:39 pm
Today someone pulled the wrong cable and so the switch sent a message saying one leg of a LAG was down. Nice feature.
However, please put the name of the switch into the From address (instead of 'root'). Currently the name of the sending switch is appended to the message subject, but that doesn't help if you want to sort or group a collection of messages by origin of messages (we keep all such messages in an Exchange public folder).
Thomas Giger
Re: Switch Name in From Header of Messages
Tue Apr 19, 2016 5:40 pm
I alerted Eric to this request
Eric Stern
Been thanked: 130 times
Thu Apr 21, 2016 4:43 pm
You can already do this. Under the SMTP configuration you can set the "From Address" field to whatever you desire.
tma
Thu Apr 21, 2016 5:14 pm
Eric Stern wrote:You can already do this. Under the SMTP configuration you can set the "From Address" field to whatever you desire.
Thanks for the hint. I wasn't sure what the syntax is and so I put a pure mail address there (because the field says "address"), i.e. switchname@domain.tld. That causes the From header to be set to "root" <switchname@domain.tld> in the message and it shows up as (the display name) root in the From column of Outlook, hiding the address part, and so I cannot sort/group on that column.
Are you saying I could add the display name part of an address somehow? How? I tried setting it to "switchname" <switchname@domain.tld> (with and without the quotes and the <>) but the field had a red background always. It seems I can't add anything that is beyond a pure RFC822 address.
Thomas Giger
tma
Thu Apr 21, 2016 5:25 pm
Guessing time: If you're using ssmtp, you would use it as ssmtp -F <switchname> -f <fromaddress> ... that would not require a change/addition to the GUI ... presuming everybody would be happy to see "<switchname>" instead of "root".
Thomas Giger
