WS-12-250-DC max cpu
mrprimo
Has thanked: 7 times
Been thanked: 6 times
Wed Apr 13, 2016 4:41 am
Hi There, I have a WS-12-250-DC sitting at full load cpu wise, its only doing 150mbit, what would cause such high load?
Re: WS-12-250-DC max cpu
Wed Apr 13, 2016 7:36 am
CPU has nothing to do with switch capacity.
CPU is there to run the UI/CLI and Daemons, the switch core is a separate thing.
Might help to know model of switch and firmware version.
Also your configuration, easiest thing to do is post up screen grabs of any Tabs with configuration changes and the Device Configuration.
mrprimo
Fri Apr 15, 2016 4:22 am
Only thing I enabled in the configuration was snmp, and ive disabled this and CPU is still max.
Been thanked: 158 times
Fri Apr 15, 2016 7:51 am
Can you please try v1.4.0rc12 - BETA / Release Candidate
If this doesn't fix the CPU utilization, we might have to remote into your machine to see why your CPU usage is so high because that is not normal.
mrprimo
Fri Apr 15, 2016 7:57 am
Back down to 42% with rc12, thanks guys :)
taormoi
Thu Feb 07, 2019 4:10 pm
Seeing the same thing today on 1.5.1rc11. Should I try rebooting the switch? Been damn cold here, -15 last night, above 0 now.
Thu Feb 07, 2019 5:45 pm
taormoi wrote:Seeing the same thing today on 1.5.1rc11. Should I try rebooting the switch? Been damn cold here, -15 last night, above 0 now.
I would reboot it then upgrade to v1.5.1
Sometimes there is a "rare" issue when the service SWITCH loads multiple times. I recently saw this on 3 of my WISP's Netonix switches, a reboot resolved it.
Stephen is working on this as it should never happen.
taormoi
Fri Feb 08, 2019 11:11 am
I rebooted it which cleared the max cpu and then rolled it back to 1.5.0 - last night it disappeared for a couple hours then came back up late in the evening. It's passing data but we can ping the switch but not login to it. Its powered by a couple of 12v solar panels. Short of driving out to reset it, is there anything we can try first remotely?
We ssh'd in and ran the reload cold command. Still cannot access the web gui.
taormoi
Fri Feb 08, 2019 1:42 pm
Update, went out and power cycled it, still cannot access the web gui remotely.
Fri Feb 08, 2019 2:00 pm
taormoi wrote:Update, went out and power cycled it, still cannot access the web gui remotely.
OK but when your on site plugged into the unit you can access the web UI?
If you can access the web gui on site plugged into it then this would tend to indicate a network configuration issue?
Users browsing this forum: Google [Bot] and 154 guests
