Installing a new site, when we break power to the switch and re establish, random ports don't turn POE power back on.
WS-12-250-DC on 1.3.9
We have also seen this on a WS-12-250-AC
Ideas?
Adam
Some POEs off after power fail
Re: Some POEs off after power fail
when you say you cut power are you allowing the switch to completely de-power?
If you cut power and re-establish power is less than 5-10 seconds the switch can be left in an unknown electrical state and power up can be erratic and random.
- eerosal
Hi, I have same issue, i cant solve the problem ...
this is our logs.
Dec 31 19:10:35 UI: Configuration changed by 212.108.130.253
Dec 31 19:10:35 UI: Port 3 PoE: changed from 'Off' to '48V'
Dec 31 19:10:35 UI: Port 4 PoE: changed from 'Off' to '48V'
Dec 31 19:10:37 switch[1438]: PoE enabled on port 3, PoE Smart is starting cable check
Dec 31 19:10:38 switch[1438]: PoE enabled on port 4, PoE Smart is starting cable check
Dec 31 19:10:43 switch[1438]: Port 3 cable check results: Ok, Ok, Ok, Ok
Dec 31 19:10:43 switch[1438]: Port 3 passed PoE Smart cable check, turning on power
Dec 31 19:10:43 switch[1438]: Port 4 cable check results: Ok, Ok, Ok, Ok
Dec 31 19:10:43 switch[1438]: Port 4 passed PoE Smart cable check, turning on power
Dec 31 19:10:43 kernel: link state changed to 'down' on port 6
Dec 31 19:10:43 kernel: link state changed to 'down' on port 7
Dec 31 19:10:43 kernel: link state changed to 'down' on port 8
Dec 31 19:10:43 kernel: link state changed to 'down' on port 5
Dec 31 19:10:46 kernel: link state changed to 'up' on port 5
Dec 31 19:10:48 kernel: link state changed to 'up' on port 8
Dec 31 19:10:48 kernel: link state changed to 'up' on port 6
Dec 31 19:10:48 kernel: link state changed to 'up' on port 7
Dec 31 19:10:49 kernel: link state changed to 'up' on port 4
Dec 31 19:10:57 kernel: link state changed to 'down' on port 5
Dec 31 19:10:59 kernel: link state changed to 'up' on port 5
Dec 31 19:11:01 kernel: link state changed to 'down' on port 8
Dec 31 19:11:01 kernel: link state changed to 'down' on port 6
Dec 31 19:11:01 kernel: link state changed to 'down' on port 7
Dec 31 19:11:01 kernel: link state changed to 'down' on port 5
Dec 31 19:11:01 kernel: link state changed to 'down' on port 4
Dec 31 19:11:02 kernel: link state changed to 'up' on port 8
Dec 31 19:11:03 kernel: link state changed to 'up' on port 6
Dec 31 19:11:04 kernel: link state changed to 'up' on port 4
Dec 31 19:11:04 kernel: link state changed to 'up' on port 5
Dec 31 19:11:04 kernel: link state changed to 'up' on port 7
Dec 31 19:11:05 kernel: link state changed to 'down' on port 8
Dec 31 19:11:05 kernel: link state changed to 'down' on port 6
Dec 31 19:11:05 kernel: link state changed to 'down' on port 7
Dec 31 19:11:06 kernel: link state changed to 'down' on port 4
Dec 31 19:11:07 kernel: link state changed to 'up' on port 6
Dec 31 19:11:07 kernel: link state changed to 'up' on port 7
Dec 31 19:11:07 kernel: link state changed to 'up' on port 8
Dec 31 19:11:09 kernel: link state changed to 'up' on port 4
Dec 31 19:11:14 kernel: link state changed to 'down' on port 7
Dec 31 19:11:14 kernel: link state changed to 'down' on port 8
Dec 31 19:11:14 kernel: link state changed to 'down' on port 6
Dec 31 19:11:16 kernel: link state changed to 'down' on port 4
Dec 31 19:11:17 kernel: link state changed to 'up' on port 7
Dec 31 19:11:17 kernel: link state changed to 'up' on port 6
Dec 31 19:11:18 kernel: link state changed to 'up' on port 8
Dec 31 19:11:20 kernel: link state changed to 'up' on port 4
this is our logs.
eerosal wrote:Hi, I have same issue, i cant solve the problem ...
this is our logs.
I see nothing wrong with your logs indicating anything.
Saying I have same problem really does not help.
Please explain your issue in more detail.
