Left and Right Arrows by Capacity Link
Samgoober
Has thanked: 22 times
Been thanked: 6 times
Tue Feb 09, 2016 9:05 am
What do the left and right arrows indicate by the speed (or capacity) rating in the third column in the GUI? I've noticed them on 1G links as well as 100/F. I can't seem to determine a pattern as to why some would have them and others not. It's almost as if it's indicating some sort of duplex, but on identical links, some will have them; others not.
They look like this:
Sam
Re: Left and Right Arrows by Capacity Link
Tue Feb 09, 2016 9:07 am
Flow Control.
Samgoober
Tue Feb 09, 2016 9:08 am
lligetfa wrote:Flow Control.
Is that good, or should I disable it?
Tue Feb 09, 2016 9:25 am
Flow control is a complex topic and cannot be simplified into good or evil. If you don't have flow control and you overrun the buffers, you have dropped packets.
I suggest you find 1.5 spare hours and look at the Youtube video that Chris posted. There are also several threads here on flow control.
Tue Feb 09, 2016 9:38 am
Those arrows indicate not that Flow Control is enabled but that the device connected to the switch has properly negotiated Flow Control.
In short you need Flow Control in a Layer 2 network but even more so with a wireless network but watch the video for WISP Switch on You Tube and read this ENTIRE thread from post 1 to last viewtopic.php?f=17&t=671&hilit=flow+control
Search this forum for Flow Control and the UBNT forums for more information.
