I'm unfortunately not that luckily with getting DHCP to work....
Here's a log output, and I simply don't understand, why the switch does not apply the setting, even though it receives an IP-address from the DHCP server....
It just reverts to old configuration....
Jan 17 03:29:24 UI: Configuration changed by 192.168.1.100
Jan 17 03:29:24 UI: IPv4_Mode: changed from 'Static' to 'DHCP'
Jan 17 03:29:24 UI: IPv4_Address: changed from '192.168.1.5' to '10.0.0.50'
Jan 17 03:29:24 UI: IPv4_Netmask: changed from '255.255.255.0' to '255.255.252.0'
Jan 17 03:29:24 UI: IPv4_Gateway: changed from '192.168.1.1' to '10.0.0.1'
Jan 17 03:29:24 UI: IPv4_Primary_DNS: changed from '192.168.1.1' to '8.8.8.8'
Jan 17 03:29:24 UI: IPv4_Secondary_DNS: changed from '' to '8.8.4.4'
Jan 17 03:29:24 UI: Switch_Location: changed from 'XXX' to 'XXXX'
Jan 17 03:29:24 UI: SNMP_Server_Location: changed from 'XXX' to 'XXXX'
Jan 17 03:29:24 UI: Discovery_Ubiquiti: changed from 'Disabled' to 'Enabled'
Jan 17 03:29:24 UI: Discovery_Cisco: changed from 'Disabled' to 'Enabled'
Jan 17 03:29:24 UI: Options_Iperf_Server: changed from 'Disabled' to 'Enabled'
Jan 17 03:29:27 system: starting ntpclient
Jan 17 03:29:30 udhcpc[2579]: udhcpc (v1.19.4) started
Jan 17 03:29:30 mini_snmpd[789]: stopped
Jan 17 03:29:30 mini_snmpd[2598]: started, listening on port 161/udp and 161/tcp
Jan 17 03:29:30 udhcpc[2579]: Sending discover...
Jan 17 03:29:31 udhcpc[2579]: Sending select for 10.0.0.50...
Jan 17 03:29:31 udhcpc[2579]: Lease of 10.0.0.50 obtained, lease time 86400
Jan 17 03:29:33 system: starting ntpclient
Jan 27 17:35:51 skywire: Reverting to last known good configuration
Jan 27 17:35:53 skywire: removing lan (eth0.10) from firewall zone lan
Jan 27 17:35:53 switch[2720]: Detected cold boot
Jan 27 17:35:55 udhcpc[2712]: Received SIGTERM
Jan 27 17:35:55 udhcpc[2712]: Unicasting a release of 10.0.0.50 to 10.0.0.1
Jan 27 17:35:55 udhcpc[2712]: Sending release...
Jan 27 17:35:55 udhcpc[2712]: bind(UDP): Cannot assign requested address
Jan 27 17:35:56 udhcpc[2712]: Entering released state
Jan 27 17:35:58 skywire: adding lan (eth0.10) to firewall zone lan
Jan 27 17:35:59 system: starting ntpclient
Jan 27 17:35:59 mini_snmpd[2598]: stopped
And yes, the time is wrong, when I click apply.....
This switch is running firmware v1.3.7. I haven't had the possibility to upgrade to v1.3.8.
Does v1.3.8 solve the issue ?
DHCP :-(
jjonsson - Associate
- Has thanked: 37 times
- Been thanked: 65 times
Re: DHCP :-(
I had to first configure the address as static. When it ate that, I could change to DHCP assigned....
Would be nice if you could just enter fallback IP-address and then change from static to DHCP.....
Re: DHCP :-(
jjonsson wrote:I had to first configure the address as static. When it ate that, I could change to DHCP assigned....
You would have to disable Revert Mode, the problem is the switch changes IP address but the UI has no idea what that new IP address will be so it can not get to it so it reverts back to the last configuration.
Solutions:
1) Disable Revert Mode under Device/Configuration by setting value to 0
2) Set Static address to what you want the DHCP to be then next select DHCP as you already figured out.
