Hi again!
Today I have a question about a fan warning. I received :
!Fan 2 is failing (0 RPM, cooling level 100)
Please to be letting me know what cooling level 100 means.
In status the fan in question was listed as Off. It came back on a bit later. So I guess it's not a huge problem maybe. But any help in understanding would be appreciated. Thanks.
question on the Fan warnings these units send
zhall - Member
Re: question on the Fan warnings these units send
zhall wrote:Hi again!
100 id a value between 0-255 which 0=OFF and 255 being full speed, it is an arbitrary number used internally.
Please ALWAYS specify the firmware version you are using becuase how do we know you are not finding a bug that was fixed in a later release.
zhall - Member
