We recently discovered that when we power down our WS-24-400A that our backhaul ports (1-4) with POE 48 VH turn off if we have them plugged into the ports while we are powering up. This caused issues because we can then no get into the switch to turn them back on due to it knocking out all the backhaul links.
Is there some kind of feature we are not aware of? Any help would be appreciated - we would like it not to turn POE off upon boot-up!
WS-24 POE to ports turn off after reboot
bluebit - Member
Re: WS-24 POE to ports turn off after reboot
This is because you are running old firmware.
Please upgrade to v1.3.8 or personally I would use v1.3.9rc14
You should take the time to upgrade your firmware on a regular basis or at least review the release notes.
viewtopic.php?f=17&t=240
