WS-6-MINI stp state not showing
jma
Has thanked: 6 times
Fri Jan 22, 2016 1:25 pm
We have switched all our toughswitches with WS-6-MINI. Everything working fine except one switch not showing the role of a port in the STP tab. It is the second switch in a particular part of the network. Setup like this:
Mikrotik Router > switch (showing STP role) > AF24 (air fiber) > switch NOT showing STP role > Switch showing STP role.
Anybody any suggestions about what we should do or is this a broken switch?
Re: WS-6-MINI stp state not showing
Fri Jan 22, 2016 2:04 pm
What version firmware are you using?
If not v1.3.9rc14 try upgrading to that version first as we only investigate bugs on the current version in development as v1.3.8 is FINAL meaning no changes will occur.
