We recently decided to create a LAG between the switch and our routers following some suggestions found here in the forums. Ever since we have been getting bombarded with:
LACP changed state to Active on port 1 (key 100) - from xxxxx-net-00 (xx.xx.xx.xx) .
And sometimes it will be port 2 (the other in the LAG group).
The switches are WS-24-400A and running firmware version 1.3.7 on both sides. They are connecting at both locations to a Mikrotik CCR1009-8G-1S running firmware 6.32.3 on them. The configuration at the switch is pretty simple: both ports enabled, key = 100, role - LACP-A, timeout = Fast, Priority = 32768.
On the Mikrotik we have created a bonding interface, MTU = 1500, mode = 802.03ad, transmit hash policy = layer 2 and layer 3, LACP rate = 1s, MII Interval = 100.
While it appears to be performing OK (we will find out more this evening) it is FLOODING my inbox.
Thoughts or suggestions? Thanks!
[SOLVED] LACP Issues
lweidig - Member
Re: LACP Issues
When you have an issue please upgrade to the latest stable version and it is always a good idea to review the release notes on any new releases including RV versions.
Please upgrade to v1.3.9rc13 and see if you still have an issue.
Release notes for v1.3.9rcX:
viewtopic.php?f=17&t=1232#p9169
Download latest firmware here:
viewtopic.php?f=17&t=240
v1.3.9rc6 - Released 12/02/2015
- Fixed Loop protection log entry refers to wrong port number
- Fixed Broadcast storm when using LACP and RSTP [Discovered by Thomas]
- Fixed Unable to change RSTP path cost for LAGs
lweidig - Member
Re: LACP Issues
I am NOT using RSTP on these switches and prefer NOT to use a RC firmware on production servers.
Re: LACP Issues
lweidig wrote:I am NOT using RSTP on these switches and prefer NOT to use a RC firmware on production servers.
There were changes to LACP to accommodate this, however v1.3.9rc13 is about to go final, I am running it at all my towers.
v1.3.7 is closed so if there is a bug in it we would not address it with a new v1.3.7 release.
v1.3.8 is also closed and would not address it in a new v1.3.8 release.
v1.3.9 is the current thread and it is about to be finalized but even if you find a bug in an older version and was not fixed already in the current version or RC version it would only be addressed in v1.3.9
All I am saying is if you find a bug in an older firmware you should first try the latest code to see if the bug is there then if it is open a support thread here.
lweidig - Member
Re: LACP Issues
I did put this RC on over night and it does seem to have resolved the issue. Thanks!
