SNMP: ifDescr and ifAlias
jbaird
Wed Jan 06, 2016 8:24 pm
On all switches/routers that I have worked with, I see ifDescr used to describe the interface "number" (eg, ether1, Gi0/1, etc) and ifAlias used to describe the interface description (eg, "Backhaul to XYZ"). The Netonix SNMP implementation seems to combine the two:
Code: Select all
IF-MIB::ifDescr.4 = STRING: Port 4 - BH To SiteA
There doesn't seem to be anything populated in the ifAlias table on the Netonix switches. This is not a huge problem for us operationally, but for standard's sake, would it be an issue or a lot of work to do things the way that other vendors do it?
jbaird
Re: SNMP: ifDescr and ifAlias
Fri Feb 05, 2016 9:48 am
Eric,
Do you have any thoughts on this?
Thanks,
Josh
Eric Stern
Been thanked: 130 times
Fri Feb 05, 2016 10:47 am
Easy enough to do, I'll add it to the list of requested features.
jbaird
Fri Feb 05, 2016 11:32 am
Thank you!
