WS-12-250-AC LACP lock up to MK RB1100AHx2
bmv
Has thanked: 5 times
Been thanked: 12 times
Wed Jan 06, 2016 4:03 pm
We have a WS-12-250-AC connected to a Mikrotik 1100AHx2 using a 2 port LACP trunk.
Connections:
Netonix ---------- Mikrotik
ETH11-------------ETH12
ETH12-------------ETH13
Yesterday, the switch lost connectivity to the router after 68 days running successfully.
The router still operated, and the point to point links we have running via this router on other ports were unaffected.
It was just the LACP link to the Netonix not working, as in no data at all running, no flicker of a few bits.
We tried disabling ETH12 and ETH13 on the router to re-establish the comms, and this didn't work. No flicker of bits of data passing. Meanwhile the Mikrotik reports the links up at 1 Gb/s, before cycling down and up on each port randomly.
When our engineer turned up, he power cycled the Netonix switch.
No change, no comms over the LACP link.
He disconnected ETH12 on the mikrotik and then plugged it in again, no change.
He then moved ETH11 on the netonix to ETH11 on the mikrotik (i.e. moving the port down on on the router). We included ETH11 on the mikrotik's LACP config and voila traffic starts to flow again!
Sorted!
We then unplug ETH13 on the router and plug it into ETH13 again after 5 seconds, no change, no activity.
We then move ETH12 to ETH12 (bearing in mind this port wasn't working with ETH11-ETH12 beforehand), and move the LACP config to include ETH12 again.
It works!
Sorted.
So basically, we had to move the ports down one in the Mikrotik.
I have no idea if this is a Mikrotik issue or a Netonix issue.
The logs on the Netonix suggest no issues.
The logs on the Mikrotik shows that the link on ETH12 and ETH12 were being dropped before re-establishing 1-3s later. So link dropped, now synced at 1 Gb etc.
What was strange about this problem was that moving the ports down 1 port on the router fixed this!
Is this a Mikoritk bug or Netonix bug?
Netonix is on 1.2.4
Mikrotik is on 6.28
Both are awaiting upgrades to latest stable.
Re: WS-12-250-AC LACP lock up to MK RB1100AHx2
Wed Jan 06, 2016 4:15 pm
Well first I would definitely upgrade the firmware! - PLEASE UPGRADE THE FIRMWARE! There were some recent fixes to LACP but I do not think those fixes are your issue but I would upgrade. I am personally running v1.3.9rc12 at my WISP and so far the only bug I have found and was reported by Les is the Clear Log button does not work.
However with that said I run LACP and Static LAGs all over my network with Netonix to assorted other devices with no issue.
There have been several reports of issues with MT gear here and most were fixes with a firmware upgrade or downgrade on the MT router.
Do a search for MikroTik here on the forums as see what you can find.
MichaelBrandl
Has thanked: 4 times
Mon Apr 11, 2016 3:58 am
Hi @sirhc
We have upgraded but continue to get this on a Different WS and a Different Mikrotik.
The original one reported above has been A-OK Since we moved the ports.
This makes me think that it's a Mikrotik issue with port 13.
We are planning to move this now.
Mike
